Old 04-23-2004, 03:03 PM   #1
grue
Member#: 17903
Default Two EJ25 DOHC questions ('98 RS)
Looking at buying a '98 RS, and have a couple of questions.
The owner said his mechanic said the head gaskets will eventually need to be replaced, but there are no leaks as of now.
How much can I expect this to cost? Will it be cheaper if I do it preemptively? Is it something I can do myself?
Furthermore, he says the car burns a little oil, but not enough to need to fill between oil changes. He states this is normal. Is it?
Thanks!
grue is offline   Reply With Quote
Old 04-23-2004, 04:18 PM   #2
linsavy
Member#: 11620
1997 GF4-STiV3 clone
A little oil burning is OK.
The HGs are prone to failure. No need to do it until it fails, just don't drive around with the engine overheating or it will warp. There is a replacement that works a lot better. Should cost between $1 and 2K, depends on who does it. Parts are only $150 or so.
linsavy is offline   Reply With Quote
Old 04-25-2004, 11:48 AM   #3
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
My '98 just turned 90K and the only things I've had to replace (more like the dealership, as I don't have the ability to lose my main car for extended times) was the front crank seal.
I'm sure if you take care of the car it will be fine. But I'm no expert on the matter.
AJ
AJ711 is offline   Reply With Quote
Old 04-29-2004, 11:54 AM   #4
jblewis
Member#: 22768
04 2.5 XT
In the three years of owning my 98 RS, including rallycrosses and several rallies worth of lead car driving, I've had to the following work on the car:
ecu replacement - throwing bogus CELs (under warranty)
D-side head gasket failure
-replaced timing belt at the same time
Timing Belt tensioner
-replace front crank seal at the same time
Have also done brake pads on all four corners, several air filters, and a fuel filter.
JBL
Why bother with a high end stereo? You can't hear it over the gravel noise!
jblewis is offline   Reply With Quote
Old 04-30-2004, 05:18 AM   #5
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
AJ
Was it easy?
SubaruImpreza_power is offline   Reply With Quote
EJ25 DOHC vs SOHC short block questions mattvct Normally Aspirated Powertrain 6 02-17-2009 01:41 PM
Injector Differences Between EJ25 DOHC and EJ25 SOHC? MY99 2.5GT Normally Aspirated Powertrain 1 04-24-2006 06:10 PM
'98 EJ25 DOHC engine/driveline/ecu annointed Private 'For Sale' Classifieds 14 06-03-2005 11:09 PM
'98 EJ25 DOHC engine/driveline/ecu, etc swap annointed Tri-State Area Forum 5 05-31-2005 01:25 PM
