Old 04-24-2004, 01:57 AM   #1
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
Default Manifold
It i use a WRX intake manifold on an RS-T do i need the throttle body From a WRX?
-Eli
squirrelmasta is offline   Reply With Quote
Old 04-24-2004, 03:21 AM   #2
Unsung Boxer
Member#: 37196
does a WRX manifold even fit an RS? I am also interested in this idea... what other manifolds are interchangeable...
I.E. will the 1.8L mani fit the 2.2? Reason i ask this is because the TB on the 1.8 sits way farther forward and would give me more intercooler clearance.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 04-24-2004, 07:47 AM   #3
Tats
Member#: 5692
WTF? YES! I am
better than you!
IIRC a WRX manifold will only fit a DOHC head.
Tats.
Tats is offline   Reply With Quote
Old 04-24-2004, 02:13 PM   #4
squirrelmasta
Member#: 33445
Cherry Red
So in other words it won't fit my 99? where is the fitment issue? Need to know soon. kinda in the middle of making a deal to get throttle body, fuel rails, risers (STI or something) and the manifold. I want to put an APS TMIC someday and i know it won't work with my stock manifold. Let me know soon please.
-Eli
Old 04-24-2004, 03:15 PM   #5
kaos200
Member#: 2692
it will bolt onto the head, but the tb cable holder is on the wrong side, its kinda a pita to fab it up at first, but once you get it down its fine
kaos200 is offline   Reply With Quote
Old 04-24-2004, 03:58 PM   #6
squirrelmasta
Member#: 33445
Cherry Red
rock on. Will my stock throttle body work on the W's manifold? and is there any advantage to the W's throttle body?
Old 04-24-2004, 04:23 PM   #7
kaos200
Member#: 2692
not without modification, and you cant run the wrx TB because the iac and tps are different (although you could rewire the tps plug to work, the iac is different)
Old 04-24-2004, 05:10 PM   #8
squirrelmasta
Member#: 33445
Cherry Red
Is this why most people go with FMIC instead of TM's when they get bigger turbo's for there set up? kinda wondering if i should get it or not now. kinda lost at what to do. and will WRX (aftermarket) injectors fit in my manifold? and i am also planning on using a Halteck E6X so would the wiring really be an issue?
Old 04-24-2004, 06:07 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Pass on the manifold. There are too many issues to making it work and too little to be gained. The SOHC EJ25 intake manifold is the achilles heel of an NA build, but with a turbo pushing the air through their you manifold is plenty big. Spend you precious dollars elsewhere...
Old 04-24-2004, 06:53 PM   #10
squirrelmasta
Member#: 33445
Cherry Red
Would PE650's work in my manifold? If not, is there something out there around 600-700 that would work?
-Eli
Old 04-24-2004, 11:01 PM   #11
spiralsmurf
Member#: 16085
2005 STi
stock wrx injectors that have been uncapped flow 740cc's average and fit into your 99 manifold.
spiralsmurf is offline   Reply With Quote
Old 04-25-2004, 01:25 AM   #12
squirrelmasta
Member#: 33445
Cherry Red
huh?
Eli
2.5GT exhaust manifold vs. WRX manifold parklax Legacy Forum 12 08-19-2003 11:18 PM
Sti V7 manifold vs USDM manifold? geronimo66 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-17-2003 12:26 AM
STi (Red) Intake Manifold verses USDM (Silver) Intake Manifold Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-25-2002 04:11 PM
MY98 Intake Manifold comparison to MY99-01 Intake Manifold latinskllz Normally Aspirated Powertrain 0 05-18-2002 02:50 PM
Intake Manifold & Turbo Manifold !?!?!? Turk Technical Forum Archive 1 08-12-2000 11:05 AM
