Old 04-24-2004, 07:16 PM   #1
inpreza kid
Member#: 3334
Default EJ22t head gasket and piston protrusion?
i've done searches over the past few days and can't find a definite answer. does anyone know from first hand experience if the pistons on the stock ej22t exceed the deck hight? i found an old post of xephyr saying it protudes .020-.030 inches. can anyone confirm this? also has anyone experimented with the phase 2 ej22 headgasket out of the MY00 NA ej22 matched with SOHC heads on the ej22t bock?
inpreza kid is offline   Reply With Quote
Old 04-24-2004, 10:32 PM   #2
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
The pistons do protrude ever so slightly, but the thickness of the headgasket and the timing of the valves are such that you'll never run into clearance issues. I am personally running an EJ22t with MY98 DOHC heads and am aware of others running with Phase II EJ25 SOHC heads and Phase I EJ22 SOHC heads.
Darshu is offline   Reply With Quote
Old 04-24-2004, 10:54 PM   #3
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
it's not the timing of the valves, it's the shape of the piston.
THAWA is offline   Reply With Quote
Old 04-25-2004, 12:13 PM   #4
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Shouldn't be a problem, I'm running Cometic, .043".
Wedge is offline   Reply With Quote
Old 04-25-2004, 12:22 PM   #5
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
If your worried about do what Wedge and I did and get a thicker headgasket, i.e. Cometic.
Graham
Graham is offline   Reply With Quote
Old 04-25-2004, 04:22 PM   #6
inpreza kid
Member#: 3334
i'll look into that. thanks guys
Old 05-30-2004, 09:19 PM   #7
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
Resurected and Swapped
i'm going with a ej22t block, 2.5 sized pistons the sohc ej25 phase II heads.- IC
IdenityCrisis is offline   Reply With Quote
Old 05-31-2004, 10:40 AM   #8
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
I'm not sure what you mean by, 2.5 sized pistons...
You do realize you can't bore the walls of the 2.2T that much, in order to get EJ25 pistons to fit.
Old 05-31-2004, 11:52 AM   #9
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
resleeveing, or at least getting them closer to the size of the 2.5 pistons. i'm just trying to match the combustion chamber of the sohc heads. - IC
FS : STi intake manifold and throttle body jcovey2.5 Engine/Power/Exhaust 173 12-05-2011 09:38 PM
Blown Head Gasket / cracked piston, Good Repair Shop? STIStalker North West Impreza Club Forum -- NWIC 14 02-04-2010 02:48 AM
ej22t heads, crank, rods pistons -Portland reddevil NWIC Private Classifieds 0 09-23-2009 01:04 PM
WTB: EJ22T Forged Rods and Pistons Cstmboxermotorsports Private 'Wanted' Classifieds 1 04-12-2007 04:42 PM
EJ22T heads, crank, cast pistons, forged rods blackbart Private 'For Sale' Classifieds 1 12-19-2005 04:04 PM
