Old 04-24-2004, 09:17 PM   #1
donut
Member#: 9957
Default Temp gauge install? / coolant trouble again
hey Guys
i bought a temp gauge a while back and forgot about it . well i just found it this morning. i tried installing it today but i couldn't find where to put the part that goes into the block. has anybody installed an after market temp gauge ?
part two
i'm losing coolant again subaru did the headgasket abot 20k ago i will blow a gasket if its that again does that additive that subaru has really work that good? i'm thinking i might need some.
thanks Matt
p.s. wut is the temp range my98rs run @
donut is offline   Reply With Quote
Old 04-24-2004, 10:45 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
the coolant additive is for an external head gasket leaks, and the DOHC motors are not part of the recall.
Jay
Old 04-25-2004, 12:43 AM   #3
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
Jay
yeah what jay said, its for all single cam motors, subaru pretty much gave the big **** YOU!! to there old school customers
YaZahX is offline   Reply With Quote
Old 04-25-2004, 07:40 AM   #4
donut
Member#: 9957
Thumbs down
man this sucks
so how much are those cobbs heads ???
how about the water temp gauge where do i stick that sucker into the block?
later Matt
FS: 60mmSTRI Racing DSD Water Temp Gauge w/ coolant sensor, gauge holder, all wirings kwan_1104 Interior/Dressup/Audio & Security 3 09-28-2008 09:41 AM
Digital sender for tranny temp gauge install PadreWRX Transmission (AT/MT) & Driveline 23 09-04-2007 06:24 PM
Trying to remove upper column cover for boost gauge install, having trouble rocketwrx Newbies & FAQs 1 02-04-2006 02:04 PM
Intake Temp Gauge Install ?? GPH993 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-20-2002 10:15 PM
oil temp gauge install? YaZahX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-14-2002 10:23 PM
