Old 04-25-2004, 12:46 AM   #1
makofoto
Member#: 25243
2006 Legacy Outback
Default Actual Figures: Toe Change when Changing Camber
A number of us were wondering how much the toe changes when changing the camber on our WRX's.
Darrin, at West End Alignment in Gardena, CA, did a bit of extra work for me to come up with these figures ...
With my NRX camber plates ... I have three degrees of camber range. At the moment I have mine set so I can go from - 1 to -4. But, without adjusting the toe ... I don't think one would ever want to use all of that range. Going from from -1 to -4 ... the total toe will change 9/8th of an inch!
So, for every degree of (negative) camber change ... there is 3/8th of an inch change in toe.
I had Darrin set my alignment so that I have 1/8th inch total toe-IN at -2.5 camber. At -3.5 camber, I have 1/4 inch (2/8th) toe-OUT. At -4.0 camber ... I would have a whopping 7/16th ... almost 1/2 inch of total toe-out.
Is that TOO MUCH toe-out to ever consider using in AX ... ? I'm hoping - 3.5 will be my "general" AX camber setting. How much toe-out would most of you consider desirable ?
When I set my camber plates for zero toe ... about -2.8+, my WRX, with Azenis tires, tends to wander ... especially on grooved Fwys. Seems like the car wants a bit of toe to have straight line stability.
Next ... calibrating my tie rods so I can adjust my toe ...
makofoto is offline   Reply With Quote
Old 04-25-2004, 06:36 AM   #2
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
The amount of toe change will also vary depending on how much caster you have.
afpdl is offline   Reply With Quote
Old 04-25-2004, 02:48 PM   #3
HoRo1
Member#: 15618
I did a time trial with just under 1.75" toe out (total). I was not a happy camper. Car all over the place under brakes, weird understeer etc
HoRo1 is offline   Reply With Quote
Old 04-25-2004, 05:02 PM   #4
jmott
Member#: 6713
2007 Prius
brown
it may also not be linear, hehe
jmott is offline   Reply With Quote
Old 04-26-2004, 01:00 AM   #5
makofoto
Member#: 25243
2006 Legacy Outback
I forgot to say that in our "test" ... we double checked the calculated toe with three camber positions ... and they corresponded perfectly ...
Old 04-26-2004, 01:02 AM   #6
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
As long as your caster stays constant I dont see why it wouldnt be linear?
Change of rear camber affect rest of alignment? vision.dynamix Brakes, Steering & Suspension 4 07-17-2009 02:07 PM
Spin off Poll : Do you actually turn your head and look when changing lanes ? ZMANNH25rs Off-Topic 36 08-31-2007 03:09 PM
throttle blip when changing gears Joraq Warranty Issues & SOA Problems 8 03-22-2002 09:15 PM
How do engine RPM's change when shifting? garface Normally Aspirated Powertrain 2 05-19-2001 06:43 AM
oil change when??? SK1 Newbies & FAQs 5 11-05-2000 04:47 PM
