Old 04-25-2004, 01:17 AM   #1
joellg
Member#: 53255
2001 RSTi-silver
2005 STI-STG1
Default tire pressure
I have an 01 RS, with an ej20t swap-lots of STI and cusco parts and 4.44 gears, and am wondering what tire pressure to use. I have s03's and am thinking maybe 38-40 in front and 40-42 in rear. What do you think?
joellg is offline   Reply With Quote
Old 04-25-2004, 02:06 PM   #2
perfusionista
Member#: 59471
2006 WRX Wagon
Crystal Gray
Can't comment on the absolute numbers as I haven't driven the S03s but have to question why you would want higher on the rear than the front. Grip is proportional to pressure and, as the scooby is nose heavy and very prone to understeer, you want to make sure you have as much grip up front as poss. Keep the front 2-5 pounds higher than the rear (unless you are taking your buddies to the golf course and have 4 sets of clubs in the trunk, when you need extra to stop the overloaded rear washing out).
perfusionista is offline   Reply With Quote
Old 04-25-2004, 03:23 PM   #3
HoRo1
Member#: 15618
I hopr that the numbers you give us are for HOT pressures.
HoRo1 is offline   Reply With Quote
Old 04-26-2004, 08:40 AM   #4
Scooby Freak
Member#: 40751
'94 SER
Not exactly. The grip won't be as good when you get above the 'sweet spot'. The tires will feel better on higher pressures, with less sidewall flex, but when they are too high grip will fade.
Scooby Freak is offline   Reply With Quote
what tire pressure to run stock? and what is a good aftermarket tire? jay25RS Tire & Wheel 6 06-13-2011 01:54 PM
New tires, which tire pressure to go by, tire or car? NewShockerGuy Tire & Wheel 7 12-04-2004 02:33 PM
Tire pressures for snow tires? TimStevens Brakes, Steering & Suspension 10 12-22-2001 05:00 AM
Tire Pressure Loss on Yokahoa Geolander Tires Rusty Russell Forester Forum 1 08-04-2001 03:00 PM
Tire Pressure for snow tires??? 99 RS 2.5 New England Impreza Club Forum -- NESIC 4 10-12-2000 09:17 PM
