Old 04-25-2004, 01:51 AM   #1
happasaiyan
Member#: 37731
Default oil consumption and synthetic oil
just a fyi for you guys...
when i was running regular dino oil for the first 10k miles, i would consume about 1 qt for every 2k miles (i change oil on 2k mile intervals), but since i switched to synthetic oil (royal purple), i have not used up a drop. same viscosity, same driving habits, same everything, just different oil. just a heads up for some of you guys worried about your cars using up quite a bit of oil.
happasaiyan is offline   Reply With Quote
Old 04-25-2004, 02:27 AM   #2
wistful
Member#: 745
2004 STi
Java Black Pearl
Is it the oil? or is it ur rings sealing properly? I was going through mad oil too in the car till 10Kish too. However, I had gone to synthetic ~ 5K miles.
Don
wistful is offline   Reply With Quote
Old 04-25-2004, 04:03 AM   #3
RichQY
Member#: 31948
2004 STi
frequently checked since adding Mobil 1.
burnt no oil even after 2 days track event..
RichQY is offline   Reply With Quote
Old 04-25-2004, 10:05 AM   #4
happasaiyan
Member#: 37731
i consumed oil in the interval right before i switched to synth...so unless its just a big coincidence, i would say it IS the oil.
Old 04-25-2004, 12:15 PM   #5
Thumper23
Member#: 11571
wow, that is a good deal of oil
(goes out and checks his)
Thumper23 is offline   Reply With Quote
Old 04-25-2004, 02:53 PM   #6
travmn
Member#: 10964
06 ForesterXT
'02 Triumph S3
i switched to mobil 1 early on and would still consume oil. i'd go more with the rings finally seating... mine didn't stop consuming lots of oil until i really ran the car hard (~7500 miles or so)..
travmn is offline   Reply With Quote
Old 04-25-2004, 03:54 PM   #7
lstepnio
Member#: 10972
2004 STi (fuxor3d!!)
2004 Forester X
I would guess it would have much more to do with the fact you have 10,000 miles and not the oil itself. I've noticed that my oil comsumption has gone done from 1.5qt, 1.0qt to .5qt between every oil change on conventional oil.
I have some Mobile 1 sitting here waiting to be poured.
lstepnio is offline   Reply With Quote
Old 04-25-2004, 05:05 PM   #8
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
What grade oil are u using? I'm using Mobil 1 15W50 for summer.
essogas is offline   Reply With Quote
Old 04-25-2004, 07:00 PM   #9
lstepnio
Member#: 10972
2004 Forester X
I was using 5w30 conventional oil for the winter season durring break in and switching to 10w30 shortly. I considered using a heavier oil and I still might switch depending on what oil analysis looks like after the switch.
Old 04-26-2004, 09:22 AM   #10
Thumper23
Member#: 11571
that's not what the manual says to use
Old 04-26-2004, 09:29 AM   #11
HD-sw20
Gone But Not Forgotten
Member#: 37056
I am still on regular oil at 14K. My car was driking 1qt every 3K miles until I hit 10K miles. Now at 14K It uses none. I'm still on regular Dino oil and don't have any plans to upgrade yet.
HD-sw20 is offline   Reply With Quote
Old 04-26-2004, 09:52 AM   #12
happasaiyan
Member#: 37731
hrm. maybe it was just the mileage. i have been driving the car hard since day 1, however.
kinda weird how oil consumption was sort of an on/off switch with using oil and not. oh well, im not complaining.
Old 04-26-2004, 10:12 AM   #13
mindchatter
Member#: 36447
Heav en for the weat
her & Hell for company
I switched to synthetic Amsoil at 4700 miles, and have burned an average of 1/2qt. between changes (every 3-5k). It does seem to be diminishing slightly w/each change though.
mindchatter is offline   Reply With Quote
Old 04-26-2004, 10:43 AM   #14
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
i did dino untill 9k,
i have had to add >1q of oil ever.
DISCOPOPE is offline   Reply With Quote
Old 06-17-2004, 10:47 PM   #15
Sanek
Member#: 41064
2004 STi
Manual does say to use 50 for severe driving conditions.
Sanek is offline   Reply With Quote
Old 06-18-2004, 12:57 PM   #16
Tobey
Member#: 21400
2015 WRX Limited
ISM
i changed to mobil 1 synthetic at 1k with my 02' wrx and i burned a quart every 3k. i blamed the consumption on changing over too early, but that's my theory which doesn't mean jack.
i am switching to synthetic at 5k on this engine. i have 2k on my current, standard oil and i am as full as the day i changed it over (at 1k miles).
it seems everyone has a different theory on oil, what to use and when to switch / change....
Tobey is offline   Reply With Quote
Old 06-18-2004, 01:08 PM   #17
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Subaru motors are known fr a long(mileage wise) breakin period,hence the oil issue,,,Thats my theory,,,etc
Rudy
jagcars26 is offline   Reply With Quote
help: odd oil consumption and engine knock silver03bugeye Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-22-2009 12:47 AM
Oil consumption and burned sti4bao Service & Maintenance 8 05-03-2007 01:16 AM
Oil consumption and damage? mpower22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 11-09-2004 04:03 PM
WRX, first oil change, and synthetic...... Philip General Forum Archive 2 01-22-2001 08:55 AM
WRX, first oil change, and synthetic...... Philip Normally Aspirated Powertrain 0 01-22-2001 08:47 AM
