#26 |
Member#: 11482
South East
Vehicle:02 WRX Acute Stickeritis |
I'd recommend the largest bar you can find for the front. Don't believe teh Biggly? Ask trhoppe how he feels about a big front bar on an otherwise stock STi...
#27 | |
Member#: 41410
Vehicle:2006 987-120 Atlas Gray |
You can find more informaiton at www.maxqdata.com. |
#28 | |
Member#: 16803
International
I'm an experienced Subaru RS owner ![]() -Matt |
#29 |
Member#: 49278
NESIC
Vehicle:11 STI SWP |
I had the same exact thing happen this weekend, I showed up and won my first autocross in the STi. I also had the pushing problem. I was trying to fool around with tire pressure to correct it, but I guess the problem is just me
This thread has been very helpful, and I thank you all for your input. Anyways Do you guys run stock tire pressures? Just wondering... |
#30 | |
Member#: 8891
International
Vehicle:2002 WRX Silver '02 SV650 |
#31 |
Member#: 25243
SCIC
Vehicle:2006 Legacy Outback Blue |
Stock Tire Pressures ? You are putting a lot of extra load on your tires ... of course you need more air ...
There are so many AutoX resources for beginners ... look around. The Grassroots Motorsports web site, tech section ... has some good articles: http://www.grmotorsports.com/techmain.php TONs of info here, tire section, etc. email me your email address so I can send you an attachment ... of our clubs Novice Handbook .. |
#32 | |
Member#: 51740
Vehicle:2004 STi A-Stock #24 Same as my Coffee : Black |
![]() On my kumho victoracers (255s) I've been running 40psi up front and about 34-36 in the rear (depending on amount of grip i want in the rear, Looser > 35 > more grip > some #psi > looser). Any more than 41 up front and the car starts to push incredibly and much less than 39 I get severe roll over. Not much of a window in my opinion. Mor experimenting to come now that the alignment has been done and the front bar will be going on this week. -Matt (maybe you guys shouldn't listen to me as I got my azz handed to me this past sunday. It was ugly. Don't think I even made top 10 Pax ) |
#33 |
Member#: 49278
NESIC
A guy running an evoIII(rhd!!) suggested i run 36 in the front and 42 in the rear. I got my fastest time on this setup, but I find it odd that its the exact opposite of the pressures you're running. Would the pressures i ran partially contribute to the understeer?
Sorry for thread hijacking and I really appreciate the detailed informative responses. Makofoto email is on its way thanks again, I'd really like to be competive and i'll take all the help i can get |
#34 | |
Member#: 51740
With the high pressures in the rear I imagine the car will probably rotate well but I find running high pressures in the back to gain oversteer makes the car more likely to snap oversteer where as lower pressires to get the oversteer result in a more progress rotation that's easyto control and catch. Any tire pressure in the rear that is not optimum is going to result in rotation. say for your setup that the rear tires generate maximum grip at 37psi... raising or lowering the pressures from that number is going to reduce rear grip and cause the car to rotate. Which direction you go is a matter of preference for the most part -Matt |
| Thread Tools | |
| Display Modes | |
| Running a crazy tune right now. What should I do? | WrxRick | AccessPort | 8 | 06-18-2007 05:16 PM |
| o man, now what did i do | BlowDro | Newbies & FAQs | 36 | 02-16-2007 04:50 PM |
| There are no mods in here right now, what can we do?? | rice h8r | Off-Topic | 23 | 01-19-2007 06:08 AM |
| Finally got a website...now what the hell do I do?! | STR8OUT | Off-Topic | 45 | 10-14-2004 01:07 PM |
