Old 04-25-2004, 10:21 AM   #1
awd4ever
Member#: 31573
I found the
meaning of life!
Default New project: What head gasket to use?
Hi, i am starting on a new project, and currently in the parts acquisition phase.
Plan: Sti block + WRX heads + 14psi(or more) on supercharger.
Options: 98 phase 2 head gasket, WRX hg, STI hg (I hear it'll have to be dremmeled to fit coolant ports?)
What head gasket will stand up to boost the best, and are there aftermarket options?
Thanks
Alex-
awd4ever is offline   Reply With Quote
Brand new ej257 head gaskets and used STi headstuds,rods,fuel pump,Tgv sensors.w/Pics JeankySti Engine/Power/Exhaust 14 12-04-2008 05:54 PM
Re used head bolts... caused head gasket to blow again? brian3676 Normally Aspirated Powertrain 14 05-01-2008 07:00 AM
what head gasket did you use on your EJ22t hybrid? 2.5rsDOHC Built Motor Discussion 18 09-13-2007 10:16 AM
HELP!! SSAC TMIC what bpv gasket to use? blackdub06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-15-2007 03:47 PM
What head gasket to use? revhigh96 Legacy Forum 0 08-04-2004 01:41 PM
