Old 04-25-2004, 10:52 PM   #1
That Guy
Member#: 23212
2002 Impreza RS
Question Intermittent CEL
Ever get one of these? I've had it twice now in the past couple of weeks. Strange because it happened both times in the same place, at the same time of day, at the same speed. And both times it went away within a day. Wierd, hey? I never bothered to get the codes pulled (if any). Should I worry about it?
That Guy is offline   Reply With Quote
Old 04-25-2004, 11:09 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Get the code(s) read and post them here. No way to help you otherwise. As long as you haven't disconnected the battery since the light was on the codes should still be in memory.
Need help with intermittent CEL!! FxD Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-09-2009 07:38 PM
Intermittent CEL - Not on long enough to read code andrewt461 Built Motor Discussion 3 03-03-2009 02:23 PM
Intermittent cel shekelaar Service & Maintenance 0 07-05-2006 04:28 AM
Intermittent CEL flyinwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-31-2005 09:58 AM
intermittent CEL help please TaiChih Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-18-2003 04:51 PM
