Old 04-26-2004, 12:03 AM   #1
SCOOBER
Member#: 223
1999 Impreza 2.5RS-T
Default Best Place To Buy LINK
Simple enough....who sells this thing the cheapest? I am under the impression it is in the $1300 dollar range, correct? Also, is there some sort of base map that comes with it to get you running?
Doug
SCOOBER is offline   Reply With Quote
Old 04-26-2004, 04:39 AM   #2
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
You find a Link Plus tell me because I need one too, and they are hard as hell to find
benjaminetanyahoo is offline   Reply With Quote
Old 04-26-2004, 10:00 AM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
yes theyre around 1300
call the link guys go to google and search for link electro or something like that i dont remember the site off the top of my head
Old 04-26-2004, 03:21 PM   #4
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
You talking about the guys in New Zealand right? Those are brand new and more expensive.
Old 04-26-2004, 05:08 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
no this is in san diego, but yes around 1300 w/ harness
Old 04-26-2004, 06:13 PM   #6
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
hmmm maybe I need to give them a call. Need to find them now, is where you got yours? Just curious
Old 04-26-2004, 06:25 PM   #7
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
yeah just gave them a call, 1350 for the ECU and 250 for the harness, and a USB port is another 100, a lot of money. They have a dealer up in Connecticut or Maryland that can do it, that is the closiest place around here for a professional install. Damn the man. Why are cars so expensive?
Old 04-26-2004, 08:20 PM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
**** didnt know the harness was that much, look on ebay, they do go on there...
Old 04-26-2004, 10:14 PM   #9
kaos200
Member#: 2692
my friend will sell his for the right price
kaos200 is offline   Reply With Quote
Old 04-27-2004, 03:31 AM   #10
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
I'll give him 500 bucks PMed
Old 04-27-2004, 03:44 AM   #11
kaos200
Member#: 2692
yah right!
Old 04-27-2004, 03:56 AM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
were you the one who posted that on RS25 when i was selling one used with the PNP harness and serial link for $1100??
PCLink $1300
PNP Harness $250-$300
Serial Link (unknown)
They are not cheap nor will they ever be since they decresed production to keep the price up...bastards
Old 04-27-2004, 06:38 AM   #13
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
PNP harness actually runs around $500 if you can still find someone to make one for you. I got my wire-in harness through ludespeed and it was $150 i think. I wouldn't recommend wire-in unless you are VERY good at soldering and wiring diagrams and your factory harness has already been cut and spliced and screwed up by the previous owner of your car- like mine was. The serial link runs around $75
So overall you are close to $1900 or so
Drac9 is offline   Reply With Quote
Old 04-27-2004, 09:44 AM   #14
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
PCLink $1300
nah man i bought mine, serial link w/ it and harness for 900, btu i had to put 150 into it ,<wrong cards> but that was used and on here, i dont wanna sell it at all
Old 04-27-2004, 12:54 PM   #15
Rabidbyte
Member#: 36039
2001 Impreza 2.5RS
Thumbs up
Well some words of advice from someone that bought their Link+ used. First of all make sure the unit is coming from another Subaru similar to yours. I bought mine off a guy in NCali that had it installed in a Miata. When the Links are originally ordered from LinkUSA they are configured for the specific application. Thing is that the Links have top boards inside them that translates the crank trigger signal and also controls other solenoids/sensors like the Stepper Motor type idle control valve. If you want to cheap out on the harness buy a used stock ECU and unsolder the plug off the board, then adapt the Links harness to it. Here is a link to the wiring for a 2.5RS to Link+. If you’re not up for the job of soldering all that together, come up with all the parts, shipping cost, and I'll do the work for a small fee.
http://www.miamiracing.com/extra/link_system_wiring.htm
Also be aware that there are a few different versions of the link firmware. The firmware is the actual software written in the Link+ micro processor. Make sure your getting a newer version of this firmware. LinkUSA charges $99 for the upgrade and this could only be done by Link. There are a few companies out there that add there own firmware to the Link, like for example FlyingMiata. As for a BaseMap, the only thing you can do is reload the link. The Link has a basemap written inside of it that will at least get your car started. From there you have to adjust the idle and the fuel curves. I have to admit I'm not a Link+ tuning guru YET, but if there is any help that I can give, I will.
George
Rabidbyte is offline   Reply With Quote
Old 04-27-2004, 01:20 PM   #16
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
The truth comes out, I guess that is why I am considering buying a new from a dealer in Maryland and get it professionally installed. Piece of mind, we will see
Side note, just got from the phone with the tuners up in Baltimore, around 2500 hundred for a new link plus, serial port, installation and a base map tune. Doesn't seem so bad after all if it gives you piece of mind ya know
Best place to buy a sti in the bay - also where to get it for invoice? maaw Bay Area Impreza Club Forum -- BAIC 9 06-27-2008 03:15 PM
('93-'01) the best place to buy rally videos online Prog Impreza Forum 6 04-18-2001 12:55 AM
Where is the best place to buy NGK VX in E-town? V6 Canada Region Forum 1 03-10-2001 12:22 AM
Best place to buy a helmet in SF Arnie Bay Area Impreza Club Forum -- BAIC 7 02-20-2001 12:32 AM
Where is the best place to buy an Impreza? Racer X Mid West Subaru Owners Club Forum -- MWSOC 6 09-30-2000 07:56 PM
Message Board Statistics All times are GMT -4. The time now is 12:08 PM.
