Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Old 04-26-2004, 05:08 AM   #1
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Default Best Turbo for the Ej22t hybrid
Trying to start a discussion on the best turbo application for the ej22t hybrid. What are some of the best turbos for the ej22t powerband with the increased limit to 7k on the RS heads? I know it will come down to power goals but something in the range of 250-275 whp with 15-20 psi daily driven?
benjaminetanyahoo is offline   Reply With Quote
Old 04-26-2004, 06:23 AM   #2
kaos200
Member#: 2692
vf22 doesnt sound too bad.
Either that or a 34
kaos200 is offline   Reply With Quote
Old 04-26-2004, 07:26 AM   #3
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
I know very little about the powerband for a DOHC/EJ22T setup for 275hp and daily-driven. Sorry.
wac is offline   Reply With Quote
Old 04-26-2004, 07:37 AM   #4
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Well I don't wanna just answer my turbo woes, but try to start a discussion on the best setup for the hybrid and it's powerband
Old 04-27-2004, 08:20 PM   #5
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
I was planning on running a GT30R/GT32 or maybe a FP 20G/Green, but I'm not sure. Thoughts??
seven881 is offline   Reply With Quote
Old 04-27-2004, 08:24 PM   #6
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Ditto on the GT30R.
Wedge is offline   Reply With Quote
Old 04-27-2004, 08:36 PM   #7
seven881
Member#: 8828
01 BRP 2.2T Hybrid
Default Garrett GT30R
On a WRX with an EJ22T bottom end it makes about 325 AWHP on 91 pump gas and 396 AWHP on race fuel. That's from Mike at MPJ out here in NorCal. This is with stock WRX heads and I think the CFM on them is lower than the RS heads, but I'm not positive. It's a custom up/Down Pipe setup, but Garrett turbos are nice.
Old 04-27-2004, 10:00 PM   #8
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Yikes, 325 to the wheels, I highly doubt the RS drivetrain can handle that much for long, and that is the the GT30R correct? Scarey fast I bet. Is this with a stock ej22t shortblock?
Old 04-27-2004, 10:06 PM   #9
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
I'm using a VF22 on my hybrid. 22lbs daily down in denver. Never had it dyno'd but it's definately quick enough to embarass the occasional LS1.
no-coast-punk is offline   Reply With Quote
Old 04-27-2004, 10:18 PM   #10
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Wow, that is what somebody suggested earlier, does it hold 22 lbs all the way to red line? No problems with reliability of the stock block and what not. Damn youre in laramie, I got a ticket there, and forgot to pay, damn Wyoming
Old 04-28-2004, 05:49 AM   #11
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
lucky no-coast-punk he has Ramirez close to him to help, damn you!
Old 04-28-2004, 01:39 PM   #12
seven881
Member#: 8828
01 BRP 2.2T Hybrid
Stock EJ22T @ 18PSI I think. I'm not sure what tranny he was using, but more than likely you'll need a new tranny.
Old 04-28-2004, 02:20 PM   #13
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
no-coast is running 22 lbs daily on the stock tranny of course he did admit he will be getting a new tranny at least it's drivable
Old 04-28-2004, 06:53 PM   #14
no-coast-punk
Member#: 49087
The car is quite driveable... just a bit noisy, not too bad though unless you ignore the ballbearing in a blender sound. FutureSTIer, don't bother with the cometic head gasket, the turbo legacy one works just fine.
Old 04-28-2004, 08:09 PM   #15
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
it's will lower the compression even more, I figure if I am going to pull the heads anyway, I might as well go with aftermarket ones that won't blow, we will see I guess....
Old 04-28-2004, 09:40 PM   #16
sime
Member#: 45275
2007 wrx
98 2.5rs,89 & 95 240sx's
what size t3/t4 turbo do you guys think would be good for a dohc 98/ej22t setup? I am only going to run the setup on my ej25 block with like 4psi for now. I was thinking about getting a straight t3. But getting something that would still be efficient at around 12-13psi when I swap in engine. I have heard alot of good things about a t3 super 60 but need more specs.
sime is online now   Reply With Quote
Old 04-28-2004, 11:20 PM   #17
no-coast-punk
Member#: 49087
T3/T4 60-1 trim with a .86 A/R should suit your needs quite nicely. Straight T3's are WORTHLESS on anything bigger than like a 1300cc motor.
Old 04-29-2004, 12:25 AM   #18
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
stop skimping go for the gusto, VF22
Old 04-29-2004, 03:11 PM   #19
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
how 'bout a stock WRX TD04 turbo? Any idea what type of power is going to the wheels on 16PSI?
cheers!
//marcus
marcus12 is offline   Reply With Quote
Old 04-29-2004, 07:26 PM   #20
seven881
Member#: 8828
01 BRP 2.2T Hybrid
I have a TD04L on mine and it's to small and jerky. I just bought a VF22 cheap, so I'll be smiling soon.
Old 04-29-2004, 07:26 PM   #21
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
seven881 is running a WRX turbo ask him, I think he's running around 10psi right now, not sure
Old 04-29-2004, 07:34 PM   #22
seven881
Member#: 8828
01 BRP 2.2T Hybrid
I was writing this while he was weeeeeeeeeee!
Old 04-30-2004, 06:15 PM   #23
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I am using a VF-29 on my build. I am also going with a higher than average CR at 8.8 or 9.0:1. The VF-29 will spool up before 3000rpms, and hold 17psi all the way to 7000rpm. The higer CR will give a little better off boost driveability. I figure along with JDM EJ20K big port heads (stock) and the STi yellow tops I have, I will be getting +/-350 HP at the crank. I want something that is very streetable and not pushing the ragged edge of power. I am a "do it once, right!" kind of guy and want something that will run 100k mi without major mechanical failure. I ran this all past Marc R. last week, and he concurred that it was a very sound set up for my modest goals...
Old 04-30-2004, 06:45 PM   #24
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
sounds good, nice compression by the way. Doesn't look like you lose all the low end like me with the lower compression. I will make up for it with boost down the road, damn it I need a Link Plus, anybody?
Old 04-30-2004, 09:11 PM   #25
Matt Monson
Member#: 832
99 2.5RS, '85 911
Or, do what I am gonna do and use a USDM WRX ECU with Cobb Access Tuner...
Best turbo for EJ22t? boostedballs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-31-2008 07:47 PM
Best Turbo for Hybrid? alex02wrx Built Motor Discussion 27 04-30-2008 12:09 AM
what is the best turbo for the STi? doublej Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-20-2004 08:02 AM
whats the best turbo for the drag strip? pedrok82 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-30-2003 09:21 PM
What's best turbo for the my setup? wavshrdr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-11-2003 07:50 PM
