Old 04-26-2004, 03:15 PM   #1
joshmeduri
Member#: 45001
03 Impreza WRX
Question D Stock Alignment Questions
I have searched and have found some helpful hints on this subject but there seems to be some debate on other areas I was hopeing for some input in these 'gray areas'.
Here's what everyone agree's on:
Max negative camber front (somewhere around -1.3 degrees, 1/8")
Toe out rear (somewhere around 1/8" to 1/4")
My question is: What toe should I run in front? What Camber should I run in the rear?
Mods will include: 22mm or more Sway, Probably Agx Struts
Thanks
Josh
joshmeduri is offline   Reply With Quote
Old 04-26-2004, 03:29 PM   #2
KC
Member#: 442
16 SS
00 S2000
Cambers not adjustable in the rear.
Toe out the front, maybe about 1/8-1/16 for turn-in.
That swa yyou talk about is only the front, right? Rear's not touchable.
Also, I don't know if KYBs are a legal replacement... as the mounting points for the spring seats MUST be in the same exact location as stock.
--kC
KC is online now   Reply With Quote
Old 04-26-2004, 03:31 PM   #3
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Camber isn't adjustable in the rear on a stock Impreza.
For front toe, 0 - 1/8" total toe out is a good place to start.
-Steve
[EDIT] cripes, KC, don't you EVER work? [/EDIT]
MNbiker is offline   Reply With Quote
Old 04-26-2004, 03:37 PM   #4
KC
Member#: 442
16 SS
00 S2000
Originally posted by MNbiker
Toe isn't adjustable in the rear on a stock Impreza.
It sure is! And I ain't tellin you how, suffice to say... it's marked very, very well.... CAMBER isn't adjustable... if that's what you meant.
(RTFM)
I'm working right now...watching some animations render in the render farm.
Old 04-26-2004, 06:16 PM   #5
MNbiker
Member#: 18148
'08 WRX
Dark Gray
(RTFM)
dohh! That's what I get for trying to goof off and work at the same time. Making mistakes at both!
-Steve
p.s. I don't know that I'd call it WELL marked. Sure wouldn't trust the marks without some toe plates to double check with.
Old 04-26-2004, 07:33 PM   #6
Soon2BRex
Member#: 57122
Default Re: D Stock Alignment Questions
[color=royalblue]
What year is your car? I have an '04 and I had a comp alignment done by a very well respected tuner shop in AZ that lots of people swear by, and they could only get 1.0 degrees exactly on both sides. I think the revisons to the '04 suspensions might have something to do with that. I have read all this stuff about getting 1.3 in the front, but it just didn't happen on my car.
These people fiddled with my car for over an hour and couldn't get anymore than 1.0. Time for some noltec plates.
Soon2BRex is offline   Reply With Quote
Old 04-26-2004, 09:22 PM   #7
KC
Member#: 442
16 SS
00 S2000
Default Re: Re: D Stock Alignment Questions
Loosen the top bolts of the strut and push them inboard... also loosen the bolts on the bottom on the hub and pull them towards the outside of the car, if they move at all.... just picks up some of the slop.
--KC
alignment question for the alignment gurus... jonjonkills101 Brakes, Steering & Suspension 2 01-18-2009 12:57 PM
stock camber on 04 wrx? alignment? questions jimtweet Brakes, Steering & Suspension 1 12-15-2005 02:57 PM
alignment question mitsubaru Southern California Impreza Club Forum -- SCIC 1 04-18-2001 05:46 PM
Alignment question wrx55 Vancouver Impreza Club Forum -- VIC 4 01-11-2001 04:38 AM
Wheel change & Alignment question? Robmat South East Region Forum 2 01-01-2001 08:02 PM
