Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-09-2000, 01:01 PM   #1
nils
Member#: 350
2015 STI
Post Suddenly mushy clutch pedal
Hi all,
Today my clutch pedal on my 98 RS got mushy after about 45mins of backroad cruising (not thrashing) and 5mins of 50mph stop and go. It took about half the pedal travel to get some feel and then the last half to the floor would disengage the clutch w/o any grinding. Pick-up was half way rather than the normal 3/4 distance up. Ambient temps are in the 80's (Mass), fluid is Ate Super Blue less than a year old (maybe 22K). Clutch is original and has almost 55K miles. After a about 15 min stop, the pedal came back, but is still softer than normal. When I stopped the fluid level was at the full line and still reasonably clear.
Boiling (ed) fluid?
TIA,
Nils
nils is offline
Old 05-09-2000, 03:22 PM   #2
Jay_UK
Member#: 296
Post
Howdy..
Could be...
Have u tried bleeding the clutch ? There is a bleed nipple on the back of the actuator (on top of the gearbox housing).
I and others have had it where the clutch pedal suddenly goes down (no resistance). A bit scarey.. it goes to the floor.... then if you lift it.. it returns higher... but once pressed returns back to normal..
I have never figured it out yet.. probably an air bleed valve doing its job...weird
J.
[This message has been edited by Jay_UK (edited May 09, 2000).]
Jay_UK is offline
Clutch pedal is suddenly easier to operate... sniper1rfa Transmission (AT/MT) & Driveline 0 10-06-2007 09:23 AM
Mushy brake pedal mn_L_owner Brakes, Steering & Suspension 2 01-12-2005 10:36 PM
help, my clutch pedal is mushy! SUBACHI Transmission (AT/MT) & Driveline 1 07-08-2003 01:15 PM
Extra mushy brake pedal ColinL Technical Forum Archive 8 07-21-2000 09:54 AM
Do you have mushy clutch pedal on a hot day? I have a fix.... ARG Technical Forum Archive 10 07-06-2000 12:38 AM
