Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-26-2004, 06:29 PM   #1
Bakes5
Member#: 60483
Default Air bag cut-off switch for 03 Baja?
I just got an 03 Baja....My first subaru. Is there any way to shut off the passenger side air bag so that I can take 3 kids with me (only 2 can fit in the rear). Specifically, I am looking for a factory type switch.
I have seen them in GM trucks so I know they exist....just don't know if they do for Subaru's
Thanks
Bakes
Bakes5 is offline   Reply With Quote
Old 04-26-2004, 07:02 PM   #2
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
I think newer Subarus have "smart" airbags that detect the weight and height of the person sitting in the passenger seat, which determines if the airbag is active or not.
I'm not 100% sure on this regarding the Baja, but I have read that the upcoming Legacy will have these automatically adjusting airbags.
BJamerican is offline   Reply With Quote
Old 04-26-2004, 09:59 PM   #3
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
It has Dual Stage Deployment Passenger Airbag which i think all cars with second generation airbags have this
ajabobrut is offline   Reply With Quote
Old 04-27-2004, 09:07 AM   #4
benrock05201
Member#: 57149
TMHK Thomas B Hanks
First 6
There is no factory airbag switch. and if you want to have one installed you might have to check with the laws in your area. In VT if your car dosen't come standard with the switch you need to fill out a form with a good reason on whyyou need the switch to be installed. But they tend to turn down any reason that is not medically related (at least here)
benrock05201 is offline   Reply With Quote
Old 05-03-2004, 09:52 PM   #5
2003Baja
Member#: 52985
the air bag censor thing is in the middle of the console. Just take off you shifter molding, and your molding that goes around the console. I bet you could simply disconnect the wires. Its amazing what you find when wiring a subwoofer to the head unit, including the security system modual
2003Baja is offline   Reply With Quote
ABS cut-off switch installation guide dant Brakes, Steering & Suspension 98 09-12-2009 01:47 AM
Kill switch Cut-off switch Battery Thezilla Engine/Power/Exhaust 0 04-10-2009 02:07 PM
Fuel pump cut off switch as security safegaurd? AJ711 Car Audio, Video & Security 15 11-14-2004 12:18 PM
What color wire(s) do you splice for fuel cut off switch? phantom Car Audio, Video & Security 5 07-19-2002 11:33 PM
ABS cut off switch WRXPOWER Brakes, Steering & Suspension 5 10-02-2001 03:05 AM
