Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 06-29-2000, 02:49 PM   #1
Joe Lee
Member#: 901
2000 2.5RS Coupe
and a red 94 Miata!
Post Amsoil filter installed - dumb question needs an answer please
OK, I put it in without any hassle and did an ECU reset. The car now idles a bit lower and acceleration is noticeably smoother throughout the RPM range. It's now very easy to rev to redline. Too, there is a nice deep growl at WOT (slightly intrusive, but if I need that much gas I probably don't care about the noise at that moment!). Where I used to have a few flat spots/hesitation (especially at @3100 rpms) it now is very smooth. Recommended mod for anyone!
OK, dumb question time As I was coming to work I was thinking about the direction of the panel when I installed it. There is a rigid mesh visible on one side and foam on the other. I faced the mesh toward the intake side, reasoning that if I sucked any debris/bugs/etc.. into the intake the mech would prevent the debris from tearing the foam. Is this correct? Should I instead turn the filter around so the hard mesh prevents any foam from being pulled into the throttle body??? This is kind of worrying me...
Joe Lee is offline
Old 06-29-2000, 03:01 PM   #2
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Post
Joe,
I believe you do have it backwards. The metal mesh is to support the foam. The filter is designed with a lighter foam first to trap big particles followed by a finer foam to trap smaller stuff. The metal mesh is glued to the back of the finer foam and supports the whole setup. Hope this helps.
Tony
Don't over oil the filter, it makes a mess (been there, done that )
Tony is offline
Old 06-29-2000, 04:22 PM   #3
richeich
Member#: 1353
2001 Impreza 2.5RS
Post
Yep, backwards. I'm glad you like it though.
Rich http://www.lubedealer.com/tulsa
richeich is offline
Old 06-29-2000, 06:17 PM   #4
Joe Lee
Member#: 901
2000 2.5RS Coupe
and a red 94 Miata!
Post
ok, thanks guys! But boy do I feel dumb!
Joe Lee is offline
Need An Answer Today Please Help! diamonki84 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 01-24-2008 09:05 PM
Dumb question, need answer fast... What coolant to use? garface Newbies & FAQs 10 08-26-2003 01:56 PM
I need an answer to this question.... WRX_02_227 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-28-2001 04:24 AM
Help, stock bushing won't come out. I need an answer now, please Aspen_2.5RS Transmission (AT/MT) & Driveline 4 09-16-2001 10:20 PM
