Old 04-26-2004, 08:26 PM   #1
Aus_RS
Member#: 35441
02 RST
GT2540R
Question Throttle body coolant path.
Had the intake manifold off the other day to move the fuel regulator out of the way (space is a premium on RHD, right side of engine, big-um brake booster and clutch cylinder). I noticed the coolant path through the throttle body. Since I live in a non-freeze climate, I was wondering about disconnecting the throttle body, and there you have it; convenient coolant source for turbo cooling. Has anyone done the same, or heard of?
Mark.
Aus_RS is offline   Reply With Quote
Old 04-26-2004, 09:12 PM   #2
Safir
Member#: 3873
. Paradise is
like Disney with hookers
i put my turbo coolant feed in-line with the throttle body, it was easy enough that i did not think it neccisary to bypass the tb entirely.
i am, otoh, interested in which direction the coolant flows through the TB...
Safir is offline   Reply With Quote
Old 04-26-2004, 11:40 PM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I've seen people re-route it on the basis that the coolant running through the TB is hot, therefore side effect is slight increase in air charge temp.
How much? I don't know... If you re-route it will you notice a difference? Doubt it...
kastle is offline   Reply With Quote
Old 04-26-2004, 11:55 PM   #4
Mancini
Member#: 20726
I ran mine off there and had no "ill" effects as far as I could see. Oh except the throttle plate sticking open once when it was really cold and the car wasn't wamped up....that was fun It's an easy place to get coolant, but it's probably easier to just tap the heater lines since you don't have to remove the damn manifold to get ahold of the lines. There's been quite a few debates about using the throttle body vs. heater lines and then which way to connect the lines to the heater. They're all on here if you search for it.
Brian
Mancini is offline   Reply With Quote
Throttle body coolant mod 5-10 WHP gain ColesSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 262 12-13-2012 11:24 PM
Throttle body coolant bypass problem? SubasaurusWrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-27-2006 02:05 PM
Throttle body coolant bypass = blocking flow instead of rerouting? athakur999 General Community 7 04-13-2006 08:33 PM
Turbo Q: Can you use the Throttle Body coolant lines for the Turbo? Kostamojen Normally Aspirated with bolt-on Forced Induction Powertrain 35 02-22-2004 09:14 PM
Throttle Body coolant line mod WRX Joe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 07-14-2002 11:55 AM
