Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-07-2000, 03:45 PM   #1
Gambit
Member#: 102
Post Dyno runs
Are dyno runs done with the hood open? I keep seeing pictures of car with their hood open when it is running on the dyno. Shiv? If so why?
Gambit is offline
Old 05-07-2000, 04:28 PM   #2
Nat
Member#: 759
2004 WRX
2000 SV650
Post
To keep the car cool. When I went to see my friend's 590hp at the wheels Z28 on the dyno they had the hood open and huge fans there to help keep things at a decent temp. I just dont think that the electric fans could keep up with the heat of full throttle runs.
Nat is offline
Old 05-07-2000, 10:07 PM   #3
Keith
Member#: 191
2012 J train
Brown
Post
its for those Ram Air setups!
Keith
Keith is offline
Old 05-08-2000, 10:06 AM   #4
Gambit
Member#: 102
Post
C'mon, surely there gotta be more response to this. It is important for my personal research.... c'mon techies!
Gambit is offline
Old 05-08-2000, 10:12 AM   #5
Ian Cook
Member#: 1228
1993 Group N Impreza
White (Mostly) ;)
Post
The fans they run at the front of the car, are to try to get some form of moving air into the air intakes, without this the car would starve of oxygen ? it is also to help cool the components as they are put under a lot of stress when on a rolling road. They are usually run with the hood open in the UK as well.
Ian Cook is offline
Old 05-08-2000, 09:17 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
Yeah, it's strictly an airflow thing to try to keep the engine cool. Even with the really big, powerful fans that dyno shops have, if you keep the hood closed the engine won't see the amount of air it will see at normal road speeds. In college I ran a number of different engines on engine dynos, and even with very powerful fans positioned no more than a few feet away the headers would glow red. hehe - it was cool!!
Pat Olsen
'99 Legacy 2.5GT 5 speed sedan
PS - Aren't the Brits so cool with their "rolling roads"? It sounds so much nicer than "chassis dyno".
Patrick Olsen is offline
Old 05-09-2000, 12:58 AM   #7
Ian Cook
Member#: 1228
White (Mostly) ;)
Post
ROFL
Ian Cook is offline
Old 05-09-2000, 08:21 AM   #8
mjos
Guest
Member#:
Post
Fans are used at the dyno on a Turbo car to force air over the IC. This is to create at least a minimal efficiency of the IC. The hood is usually open to watch engine externals under high RPM to make sure all is well and sometimes to watch fuel pressure using a gauge while under boost. Yes, airflow will also help to keep the motor and turbo a bit cooler too. The small fans that most dynos I've used are not very effective though. Dynoing in a windtunnel with the hood down to simulate going down the road would be ideal. These conditions would give a better reading of power under true road conditions.
Spraying the IC with Water helps to keep it more effecient while on the dyno also. If you don't, it gets real hot and you loose most of the benefits of having one. Spraying NOS on the IC works the best. I measured 30 more real HP by spraying the IC with NOS on the Dyno on my Supra TT. I haven't tried this with the Scoobie yet. This also works well at the 1/4 mile track just before a run...just don't let the track officials see ya doing it
Mark J.
99' RS Turbo www.subaru.stinsonweb.com
"Real Dyno Charts Posted"
Old 05-09-2000, 11:59 AM   #9
bryanw
Member#: 807
2002 WRX Wagon
Post
Yes, it's to keep the engine cool. Remember the majority of engine cooling comes from air fed into the grill (and other areas) when the car is moving. On a dyno, obviously, the car is not moving, so it is not getting the normal air cooling. Engine's are designed to run at normal temps at IDLE when the car is not moving. But if the car is sitting still and the engine is running at 5000 rpm, there's going to be considerable heat.
bryanw is offline
OBS Turbo/Nos Dyno Runs Kevin Thomas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-01-2001 07:10 AM
Converting Dyno Run Files Kevin Thomas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-01-2001 12:59 AM
Dyno Runs.. AWD car on a 2WD dyno... WTF Mike Moffa Technical Forum Archive 7 07-18-2000 08:31 PM
Dyno run on MY00 Keiho Canada Region Forum 7 06-01-2000 04:02 AM
Dyno runs on MY00! Keiho General Forum Archive 0 05-31-2000 08:02 PM
