Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-08-2000, 09:09 PM   #1
burr101
Member#: 907
2002 WRX Sedan
Question MY 2000 air intake questions.
I want to fiddle w/ my intake without destroying the stock parts. I was thinking of using 3" silicon tubing from SAMCO (used in May 2000 SCC, "project impreza"). I want to run the tube from the air box right to the fender wall, to get that wonderful cold air. Sounds easy enough, am i forgeting something? Anyone ever done anything similar? And one other thing where the hell is the MAF sensor, not in the tubing right?
Shaun
burr101 is offline
Old 05-08-2000, 09:25 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
1 - There is no MAF sensor. MY00 uses a MAP sensor mounted on the top of the intake manifold.
2 - Yes, lots of people have run tubes to their fender and it works just fine. Personally, I leave the outlet on the filter box open just where it is and it works great. It does tend to suck hot air, but if you need the power, usually it is during an event where you can take off the underside of the hood scoop to get cool air in that way.
BTW, that 'Project Impreza' is a 99 so there will be a few differences. For instance, you don't need to take off the wheel and pull back the fenderwell to get a snorkus-thing out of the fender because in MY00 they don't have one there. It is just an open fender.
8Complex is offline
Old 05-09-2000, 12:57 AM   #3
larryganz
Member#: 1061
2004 STi Blue/Gold
Wife made me downgrade...
Post
I feel I get slightly more power with my cold air tubing than driving with all the tubing off and the hood scoop open for cool air.
Leaving the scoop closed also keeps the engine cleaner from dust and dirt.
Larry
www.ImprezaRS.com
[This message has been edited by larryganz (edited May 09, 2000).]
larryganz is offline
Old 05-09-2000, 07:08 AM   #4
ravent
Member#: 500
00/+ RS/OBS
white
Post
This weekend we are having an install-fest during which I hope to find areas of hot or cold air in the engine compartment...currently I am using a cone filter on the throttle body and the hood scoop open. I have driven through several rain storms with (to my knowledge) no ill effects but "I DO NOT RECCOMEND THIS YET".
I would like to create a filter (for bugs and small animals) in the hood scoop and a
reverse scoop under the throttle body to capture more of the air (with provisions to
allow water to go past)coming in and also a
larger bell on the throttle body to act as a velocity stack...any ideas???
ravent is offline
Old 05-09-2000, 07:27 AM   #5
burr101
Member#: 907
2002 WRX Sedan
Post
what about the tube that branches off and points straight down, its about 14" long 1-1/2" tubing. I was assuming its a safeguard against hydrolock do you folfs know its real purpose???
Ravent,
have you checked out the 2000 or 2001 Ford Mustang Cobra, that uses a velocity stack. Maybe you can get inspired
Shaun
burr101 is offline
Old 05-09-2000, 07:41 AM   #6
ravent
Member#: 500
00/+ RS/OBS
white
Post
I have not seen it but will check today...now my plan is to use a bell from my
sentra aftermarket intake w/ a K&N filter
ravent is offline
Air Intake Questions adambmour Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-31-2003 07:43 PM
Cold Air Intake Question adambmour Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-12-2003 11:55 PM
cold air intake questions nhluhr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-01-2001 05:54 PM
cold air intake question Norris Normally Aspirated Powertrain 24 06-06-2001 10:08 AM
cold air Intake questions from a newbie! cRayZee Newbies & FAQs 18 05-04-2001 10:05 PM
