Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-08-2000, 09:09 AM   #1
Tim K.
Member#: 214
2014 Massey Ferguson
Red
Post No More Turbo Lag
The turbocharging experts at Garrett are going hybrid with their Turbopac and Dynacharger concepts. The former uses an electric motor to spool up the turbocharger and eliminate lag. The latter also uses the motor as a generator to regulate the charge-air supply (instead of a throttle) and thereby generate the power it later gives back when driving the turbo. The goal of both systems is to provide supercharger response without the parasitic losses.
*as seen in the June 2000 issue of Car and Driver*
Tim K. is offline
Old 05-09-2000, 08:38 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I still want to know what happened to the hydrocharger concept that used the coolant flow system, almost like the supercharger is belt driven.
8Complex is offline
Level 10 Automatics Are Faster Than Sticks ! NO TURBO LAG. 20%OFF LEVEL10 Drivetrain 3 07-28-2010 01:25 AM
More power in turbo lag than in turbo!HELP 99subi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-06-2005 02:47 PM
Does a larger TMIC cause more turbo lag ? ronf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-16-2005 11:27 AM
Will a larger top mount intercooler cause more or less turbo lag? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-12-2003 10:07 AM
('93-'01) New turbo = no more lag !!! twiztid Impreza Forum 5 08-26-2001 09:53 PM
