Old 04-27-2004, 09:27 AM   #1
lukerussell
Member#: 14723
2008 Unlimited AWD
Redline Time Attack Champ
Default ye olde spring rate query
JIC flta2-rs w/ race damper. On STi. For track mostly, i'm not a big autocrosser. I'm a thinkin 8 kg/mm front, 7 kg/mm back (448 lb/in and 392 lb/in).
I know a bunch of you wrx guys run stiffer springs in the back, but I think the difference can be made up with the dccd all the way back and if that don't work, a big fat rear sway bar.
Opinions from those smarter than me, please.
luke
lukerussell is offline   Reply With Quote
Old 04-27-2004, 09:43 AM   #2
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Yup.
With the STi I don't think you need the higher rear rate because of the diff.
Just my opinion though from driving miranda's STi.
You can always throw the 10Ks on the rear if you don't like the way the car handles.
-Tom
not smarter.....
trhoppe is offline   Reply With Quote
Old 04-27-2004, 09:54 AM   #3
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Personally, I'd go with even F/R rates. I believe that's what JIC typically recommends, when you get custom rates for track use. I'd probably go with 9K/9K, unless you're doing a lot of street driving.
-Steve
MNbiker is offline   Reply With Quote
Old 04-27-2004, 10:36 AM   #4
lukerussell
Member#: 14723
2008 Unlimited AWD
i'm thinking the 8/7 might be a little wimpy. how come coilovers for the evo are always around 600lbs? the sti was actually tail happy when i did an autocross. but at sebring, it pushed like a pig all day long. i like the 9/9 idea.
luke
Old 04-27-2004, 10:58 AM   #5
Watkinsm3
Member#: 51740
2004 STi A-Stock #24
Same as my Coffee : Black
Originally posted by trhoppe
Yup.
I agree 100% with this as well. You won't be able to put power down as efficiently with a rear biased setup in my opinion.
-Matt
Watkinsm3 is offline   Reply With Quote
Old 04-27-2004, 11:00 AM   #6
jmott
Member#: 6713
2007 Prius
brown
Default Re: ye olde spring rate query
The bigger/faster the turn, the less you should understeer anyway.
edit: this seems not to agree with your experience though, strange
luke
jmott is offline   Reply With Quote
Old 04-27-2004, 11:14 AM   #7
lukerussell
Member#: 14723
2008 Unlimited AWD
i think it was tail happy on the autocross course because i was on the stock springs. there is so much body roll that it would snap from side to side in a slalom and break the rear loose.
on a race track you don't have those sudden transitions, so it just pushed.
luke
power to the rear. that's why i was originally doing 8/7, but temporarily forgot when i said 9/9. i think i'm now at 9/8.
Old 04-27-2004, 11:24 AM   #8
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Sweet thing about the WRX/STi is that it can take the same length springs all around.
Pick up the JICs with a set of 8K,9K, and 10K. Then you can swap to your hearts content until you get a setup that works well.
Go with 9/8 first. If the car works well but you feel like you need more spring, 10/9. If you need more oversteer 9/10. REALLY need oversteer? 8/10.....Car too loose with 9/8? 10/9 Possibilities are endless......
-Tom
Old 04-27-2004, 04:09 PM   #9
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
As they say, loose cars are fast cars - how fast do you want to go?
- Steve
zzyzx is offline   Reply With Quote
Old 04-27-2004, 04:29 PM   #10
MNbiker
Member#: 18148
'08 WRX
Dark Gray
-Tom
Note - standard 2.5" ID springs will fit on the JIC's just fine, so you can buy Hypercoil or Eibach ERS springs and save big $, versus what JIC charges. Note #2 - My JIC's use 8" springs on all 4 corners. However, I believe the new long-stroke rears use a longer spring in back, which would make spring swapping a bit more difficult.
-Steve
p.s. I'm using Hypercoils
Old 04-27-2004, 04:48 PM   #11
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
That blows! Since they are height and preload seperate adjustments, can you just adjust the same height spring on the front to work right??
-Tom
Old 04-27-2004, 09:48 PM   #12
jcroy66
Member#: 42675
2003 WRX #177 STX
www.TeamSoloRacer.com
The new JICs on our living room floor have 8" springs front and rear but we ordered them with helpers at both ends, 1.6" in the front and 2.1" in the rear. And after looking at the prices of JIC vs. Eibach springs if we decide to change rates I doubt we'll buy the JIC springs.
jcroy66 is offline   Reply With Quote
Old 04-28-2004, 12:22 AM   #13
MNbiker
Member#: 18148
'08 WRX
Dark Gray
coolness.
Old 04-28-2004, 03:27 AM   #14
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
-Tom
You can put an 8 inch on the rear without changing the ride height but you will loose some shock travel.
afpdl is offline   Reply With Quote
Old 04-28-2004, 02:02 PM   #15
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
- Steve
Don't they say the same thing about women?
I agree with Tom's idea of 8k/9k/10k as far as a flexible setup, although if you're doing the helper springs then...
DrBiggly is offline   Reply With Quote
Old 04-29-2004, 09:08 PM   #16
lo-buck
Member#: 28913
1990 H2 civic
white
what tire do you plan to use? i think that would effect how stiff you go on spring rates (at least a little bit) as well as how much street driving the car would see and how stiff you can stand on the street. i would go with somehting along the lines of 10k/9k if you want to keep some understeer in the car.
-spenc....thinking 10/12 would be fun in an autocross car.
lo-buck is offline   Reply With Quote
Old 04-30-2004, 02:07 AM   #17
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
I think that would be a little excessive in the rear for an sti. Doesnt look like it would need anything greater then even spring rates to rotate.
Old 04-30-2004, 08:36 AM   #18
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
If/when you order your struts, the part number will tell you if you have the longer travel struts or not.
you probably have the KRA-08A in front and KRA-16A in the rear. They reccomend the 225mm springs for, unless you use the 200mm springs with helpers. JIC's 225mm springs are limited though in terms of available spring rates. Don't know if Eibach has a similar length spring with higher rates available.
My RS came with the 08B fronts and 16B rears which have a shorter strut travel. I'm looking into getting them upgraded to the A's
trojan9x is offline   Reply With Quote
Old 04-30-2004, 08:48 AM   #19
trojan9x
Member#: 3169
also, where online can I see the coil springs for eibach to use on coilovers?
Old 04-30-2004, 09:13 AM   #20
PhilC
Member#: 35190
2003 WRX STX #77
www.soloracer.com
Where would you find the model number on the units? They are at home and I'm at work so I can't search all over for the model number so if you can say where the model number is it might save me some time.
If you Google "Eibach Race Springs" you'll come up with hundreds of sites that sell them and you can get more information on them. Only thing is that Eibach's actual site uses a goofball database system that does not appear to actually work so you'll probably want to look at one of the many sites that sell them.
PhilC is offline   Reply With Quote
Old 04-30-2004, 09:40 AM   #21
trojan9x
Member#: 3169
On the strut, the part number is right below where the piston comes out of the strut. Shouldn't be that hard to find.
Old 04-30-2004, 10:40 AM   #22
trojan9x
Member#: 3169
here is a nice page for the hypercoil springs
http://www.eshocks.com/hyp_ind.asp?S...&Free_Length=8
and here is one for eibach springs
http://www.fast44.com/eibracsp4.html
Old 04-30-2004, 03:21 PM   #23
lukerussell
Member#: 14723
2008 Unlimited AWD
i went with 9/9. i think that will give me what i'm looking for. if not, new springs are just $40 away at eshocks.com . what a deal. thanks mnbiker for showing me the hypercoil light.
luke
Old 04-30-2004, 03:45 PM   #24
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
luke
Luke,
What suspension do you have that you can change the springs on it for $40?
Old 04-30-2004, 03:46 PM   #25
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Originally posted by DrBiggly
Luke,
Any coilover that takes 2.5x8 inch springs. I think he has the jics but there are others you can do the same thing on.
teh monstAr goes to ye olde recorde shoppe: January Edition WagonMonster Off-Topic 39 02-06-2007 06:23 PM
MonstAr Goes to ye olde Amoeba Music (AC Lerok Edition) WagonMonster Off-Topic 35 11-01-2005 01:10 PM
MonstAr Goes To Ye Olde Record Shoppe WagonMonster Off-Topic 15 10-18-2005 10:46 PM
Ye Olde Wheel Shop Review serendipity Mid Atlantic Impreza Club -- MAIC 12 09-28-2004 02:31 PM
What, No Happy Birthday to Ye Olde Oily One? Subi Chicky Off-Topic 5 06-09-2004 04:50 PM
