Old 04-27-2004, 12:06 PM   #1
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Default Boosting problem with new stage 4/UTEC
I got a basic map for stage 4 plus FMIC and it boost about 10psi till 5K rpm's and from there it opens up to whatever I set it.
Feels like a two stage nitrous system
Leonardo is offline   Reply With Quote
Old 04-27-2004, 06:38 PM   #2
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
bump for my por car!
Old 04-28-2004, 09:04 AM   #3
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
sux!
Old 04-28-2004, 09:15 AM   #4
modvp
Member#: 25215
Are your parameters set correctly? Double check them.
modvp is offline   Reply With Quote
Old 04-28-2004, 11:03 AM   #5
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Got a log to share?
Zola is offline   Reply With Quote
Old 04-28-2004, 01:07 PM   #6
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Leo: If you can, take screen shots of the hyperterminal windows on all the seperate parameter submenus for me, as well as page one and two of your boost map in question.
Thanks bud!
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 04-28-2004, 02:32 PM   #7
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Thanks!
I will but I need to find a laptop to hook up!
It was a Stage 4 map that was kinda modded to work with FMIC.
Since we have no AWD dyno here, everything is road tunned.
Old 04-30-2004, 12:41 PM   #8
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
One thing I forgot to mention is that boost is controlled by a Profec-B Spec 2 (the old one)
Old 04-30-2004, 12:47 PM   #9
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
hahahaha... well that has nothing to do with the UTEC then
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 04-30-2004, 10:44 PM   #10
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
weird
with the profec on or off it does it. could it have something to do WITH the Utec not being mapped at all with the VF34? Like it spools up but when the 5k rpm's come in, it spins the turbo as it should?
I might just replace the Profec with the TXS MBC to see what happens.
The tunner will tune it on tuesday but it's just driving me wild till then cuz I love how it feels above 5K
Old 04-30-2004, 10:55 PM   #11
hippy
Member#: 36528
2002 Impreza Wrx
Sounds like your running of wastegate spring pressure. This basically means that the boost control device isn't venting enough air from the wastegate actuator vacuum tubes. This makes it so the wastegate opens automatically. You might wanna look into hooking the boost control and boost control hoses up correctly. If you're running the utec for boost control like you should be since it can be dialed in better for use with the utec(imo), you might wanna do a search on "brass restrictor". If everything's hooked up correctly, try to get your boost controller to vent a lot more air from the vacuum tubing then it's venting right now.
peace
Old 05-01-2004, 08:30 AM   #12
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Is the brass restrictor the one that is close to the turbo outlet port? Lithe the one inside the hose? I took that off when switching hoses. Shoould I put it back on?
I'll check the hose connections.
Leo
Old 05-01-2004, 11:00 AM   #13
hippy
Member#: 36528
2002 Impreza Wrx
Leo
si senior....it's the one in the hose between the t and the turbo.
peace
Old 05-01-2004, 11:02 AM   #14
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
So, should be in place or not? Can that be the whole problem?
Just checked all the hosing and nothing seems to be wrong.
Old 05-02-2004, 08:36 AM   #15
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Thanks hippy!
PROBLEM SOLVED!
Damn little hose with the restrictor in it was the problem. now boosts like mad
Old 05-02-2004, 09:49 AM   #16
hippy
Member#: 36528
2002 Impreza Wrx
anytime.....now ya don't need to wonder why that little thing was in there.
peace
Problems with my stage 4 setup. emsmap UTEC 3 03-16-2009 01:27 PM
have boost problem with cobb stage 2 map or PDX maps alvinli217 AccessPort 23 12-04-2008 03:59 PM
!!Boost issue with my stage 4...HELP kwilson36 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-09-2005 05:46 PM
problem with custom stage 4...any help? b00st3d Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-18-2002 09:35 AM
