Old 04-27-2004, 02:08 PM   #1
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
Question Optima Red Top Group 35 R
As I've accidentally left my dome light on overnight for more than two occasions and have my car jump-started by the owners of my parking garage, I believe that it's about time to replace the stock battery and upgrade to something a bit more reliable. Yes, I realize that it was my absent-mindedness that destroyed my the stocker, but I had considerable problems starting it in near-freezing temperatures.
Being the impulsive guy that I am, I did some research and bought the Optima Redtop G35 R battery from a reputable site (BatteriesRUS.com) and it is shipping as I write. However, I need to know what I need to do to install the battery. Do I have to do anything to the stock battery terminals (IE modify them) or can I use them? What about the battery tie-down? Is it practically a plug-and-play fit, or will this battery require a longer starter cable? Can I do all this myself (I have moderate experience with tools and have done some of my own mods) or is it better to have Autozone help out on the install? I need the battery in before my long journey home so I need to install it ASAP when it gets here.
Thanks in advance!
PS: Yes, I realize this isn't N/A related per se, but I've seen threads on batteries in almost every forum (N/A, 2.0 Turbo, STi, Electrics & Lighting, Car Audio, Service & Maintenance, etc.) and didn't know where to put it. I'm specifically talking about the fitment for the GDA EJ25.
DrBoy01 is offline   Reply With Quote
Old 04-27-2004, 02:35 PM   #2
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I've heard that one of those batterys has the terminals on the wrong sides, make sure the orientation is correct (positive, and negatives line up).
AO
m750 is offline   Reply With Quote
Old 04-27-2004, 02:54 PM   #3
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
I always heard that the yellow top was better (better deep cycle capability and all the cca you need). I also read somewhere that Optimas were heavy and there was another battery out there that was a better choice as far as weight savings go; why did you opt for the red top?
powerlabs is offline   Reply With Quote
Old 04-27-2004, 02:58 PM   #4
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Lighter batteries have less CA/CCA, fewer amp hours (AH), and usually require some sort of modification to fit. While the Red Top is comparable to the stock battery in weight, it is much more powerful and will last for far longer. Finally, lighter batteries tend to die out faster and don't work well in cold weather. Because my stock battery had considerable trouble starting my car in colder weather, I decided that the Optima was the best choice for my application.
Old 04-27-2004, 07:33 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If it's the "R" type it should be a direct drop-in replacement. The "universal" 35/75 has relocated terminals which require a longer starter cable, but the "R" has the terminals in the stock locations, at the outside corners of the battery. It is not as tall as the OEM batt, but the factory hold-down will still work. As for weight the 35 is within a pound or so of the stock battery's weight, it's the 34's that are several pounds heavier.
I've had a 35 Red for almost two years and it's been a huge improvement over the stock one, especially in the winter. You are doing the right thing.
Old 04-27-2004, 11:38 PM   #6
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Thanks for the vote of confidence, and the information!
Old 04-30-2004, 03:40 PM   #7
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Any idea on what the installation procedure is for a new battery? I know I have to take off the stock battery clamps and stuff, but I don't know what order I'm supposed to take them off. Also, how do I remove the stock battery-tie so I can remove the stock battery? Is there anything else I'll have to do?
Thanks!
Old 04-30-2004, 03:57 PM   #8
powerlabs
Member#: 45790
SUPERCHARGED
How about the yellow top? Isn't it better than the red top?
I'd really appreciate a link where I can learn more about different types of car battery.
Old 04-30-2004, 04:58 PM   #9
sidewayz
Member#: 5810
2001 S366 2.5RS
Im using the Orbital "black top" from Exide...you really dont need a deep cycle battery unless you are using it with an exsiting battery.
the red top or any "starting" battery will be fine
with my battery I have left my radio on for over 6 hours playing load and never had the battery die.
sidewayz is offline   Reply With Quote
Old 04-30-2004, 05:33 PM   #10
powerlabs
Member#: 45790
SUPERCHARGED
Well, my Wallmart battery works great too... Its been in the car for almost 2 years now, it starts the engine in the cold, runs the lights and radio, etc etc etc... The bottom line is that pretty much anything will work. I'll bet if you got 30 rechargeable "D" cells off Radioshack and strung them up 10 in series, 3 banks of 10 each in parallel it would run your starter reliably for years. What I am curious about is what the practical difference is between a red top and a yellow top. The yellow top is deep cycle, the red top supposedly produces more cold cranking amps. But if a wallmart battery produces all the CCA you need, wouldn't it be advantageous to have a battery that can fulfill the CCA requirement AND run deep cycle?
Old 04-30-2004, 07:12 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The Optimas use a different construction than your standard Wal-Mart or other lead-acid battery. You can read more about it here-
http://www.1st-optima-batteries.com/
Old 04-30-2004, 07:41 PM   #12
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
DIE-HARD!
Honkey3k is offline   Reply With Quote
Old 05-01-2004, 12:32 PM   #13
avk
Member#: 17252
'06 WX8
59E
Die-Hard is same as Wal-Mart, at least in the most common sizes: both brands are made by Johnson Controls. Of course it can change.
avk is offline   Reply With Quote
Old 05-01-2004, 03:35 PM   #14
Basshead
Member#: 112
2011 Jetta TDI
here's a tip...change you dome light to an LED strip...no more worries at all....btw my red top has been flawless for the past year..
Basshead is offline   Reply With Quote
Old 05-01-2004, 08:25 PM   #15
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Bah, all these posts and no install help! Help me, Mulder
Old 05-01-2004, 09:02 PM   #16
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What more can I tell you? Take the old battery out and put the new one in.
Old 05-02-2004, 10:04 AM   #17
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
Optima makes a reverse post red top. Its just orange instead of red .
imprezzakc is offline   Reply With Quote
Old 05-02-2004, 11:04 AM   #18
Siper2
Member#: 1134
2007 BMW 328xi wagon
I was in the same predicament this past winter; I needed to have my car jump-started two or three times when our New Hampshire winters were hitting like a zillion below zero. (I'm now in PA. But that has nothing to do with the weather. )
I was really shopping for Optima, but honestly I ended up with a Die Hard Gold. Sears now sells Optima batteries, but to be perfectly honest, the Die Hard's warrantee is better. That and if anything ever goes wrong, Sears is everywhere in the known universe, and even though the company now covers Optima, Die Hard is one of their cornerstones. It has like 100 less crank amps than the Optima, but still has about 150 or 200 or something more than the stock one.
And since my OE one lasted 3.5 years, I'd say I'm good to go.
-S2-
Siper2 is offline   Reply With Quote
Old 05-02-2004, 01:29 PM   #19
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
The problem is, I don't know how to do that exactly. I'm afraid of hurting myself via electrocution or battery acid Seriously though, how do I get the battery tie off, how do I remove the post clamps, etc.
Optima Yellow top Group 35 Deep cycle battery. GARGOYLE SCIC Private Classifieds 8 01-25-2010 05:24 PM
FS: 4 Optima Red Top Group 35 Batteries Brand New triniboy Canada Region Private Classifieds 0 10-19-2009 04:39 PM
Optima Red Top 35-910 Bishop Southern California Impreza Club Forum -- SCIC 22 11-17-2008 09:11 PM
wtb 090-04 legacy subwoofer. optima red top 35 battery lgkahn NESIC Private Classifieds 0 10-02-2007 07:57 AM
Optima Red Top Group 35 install pics Peaty Electrical & Lighting 8 12-11-2004 08:57 AM
