Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 06-28-2000, 09:26 AM   #1
BoomerRS
Member#: 1271
98 RS
****in Rally Blue
Unhappy Oil leaking from spark plug area... anyone else had this?
Boom and I put new plugs in my 98RS last night and the block around one of the plugs was really dirty... when we pulled the boot off the inside was coated with oil. Our guess was the gasket was not sealed anymore. I made an appt at the dealership next week and I should be covered under warranty, but I just wanted to see if anyone else has seen this. Thanks
Boomer
BoomerRS is offline
Old 06-28-2000, 10:27 AM   #2
greg
Member#: 81
Post
or maybe the plug got loose and oil was coming out through the threads. Did it idle rough or run rough at all?
greg is offline
Old 06-28-2000, 10:40 AM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Pray it is a head gasket.
If not, it's probably rings. Not cheap, and not uncommon for the early 2.5L skirtless pistons.
ColinL is offline
Old 06-28-2000, 11:38 AM   #4
BoomerRS
Member#: 1271
98 RS
****in Rally Blue
Post
spark plug was not loose and the car has been running fine. i noticed no difference after swapping the plugs. hmmm... i wonder if this is more serious than i thought.
BoomerRS is offline
Old 06-28-2000, 02:15 PM   #5
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
Check your breather hose first. It might have a crack or be loose. It will spit oil right in the SP area.
Imprezer is offline
Old 06-28-2000, 03:30 PM   #6
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
Post
I'd bet its the gasket that seperates spark plug area from the valve area. I'm drawing a blank for the correct name for the part but its fairly common for them to leak. Take a look in the photo below (Courtesy of Cobbtuning)BTW the SHOC use a tube for this which are even more prone to leak.
<img src=http://www.cobbtuning.com/images/dohc-engine02.jpg>
[This message has been edited by DonA (edited June 28, 2000).]
DonA is offline
Old 06-29-2000, 12:08 AM   #7
boxerman
Member#: 644
Post
If it were rings you should notice some smoke and oil consumption.
Tim
boxerman is offline
Old 06-29-2000, 05:16 AM   #8
BoomerRS
Member#: 1271
98 RS
****in Rally Blue
Post
Imprez - Well, there was oil inside the boot, so I know that it is coming from the inside.
Hey Don - That was my guess too. It must not be leaking bad becuz my oil level has been fine.
The lower left bolt is dirty also, so I think that I am leaking in 2 places. Fun. It should be covered under warranty though.
Thanks everyone.
BoomerRS is offline
Has anyone else had this problem? MrsBenton_0311 Mid Atlantic Impreza Club -- MAIC 10 04-30-2006 02:42 AM
Stuck in an insurance dilemma, anyone else had this happen? Inspectorlee General Community 25 01-25-2006 10:40 PM
Fuel leak in spark plug area gordon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-06-2005 09:51 AM
Oil leaking from spark plug wells normal?! Seeing StaRS Normally Aspirated Powertrain 25 06-28-2004 11:11 PM
Found Oil Leak in Spark Plug area Omega2000 Service & Maintenance 2 04-24-2004 11:32 AM
