Old 04-27-2004, 04:31 PM   #1
codyek
Member#: 60558
2003 2.5 rs
midnight blue
Default 03' 2.5 rs lude speed stg 2
i just bought a lude speed stg 2 turbo kit for my 03' 2.5 from someone who had it on a 00' would everything be the same. he didnt have all the instructions to in stall it does anyone have them, and would wireing the s-afc to the comp. be the same as the 00' as for my car
codyek is offline   Reply With Quote
Old 04-27-2004, 05:19 PM   #2
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
Why are you using an s-AFC? didn't you get a link with it or was that only the stage 3? and is the 03 a MAP or a MAF?
-Eli
squirrelmasta is offline   Reply With Quote
Old 04-27-2004, 05:56 PM   #3
codyek
Member#: 60558
2003 2.5 rs
midnight blue
not sure thats why im askn
Old 04-27-2004, 08:32 PM   #4
03rsturbo
Member#: 26164
2005 Legacy GT
The wiring for the ecu is different on the 03 than on the 00 and if I remember correctly the ludespeed stage 3 did not always come with a link ecu it depends on when you got it but I could be wrong on that
if you what the wiring diagram for the 03, pm me I'll email it to you
03rsturbo is offline   Reply With Quote
Old 04-28-2004, 01:31 AM   #5
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
03 should be MAP, and i thought the 00 was the first year of MAP for the RS as well???
yes i would recommend a link if you can get it.
Ben
Old 04-28-2004, 04:36 AM   #6
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
00 and up are MAP
Drac9 is offline   Reply With Quote
Old 04-28-2004, 10:19 AM   #7
codyek
Member#: 60558
2003 2.5 rs
midnight blue
cool i didnt know, but for right know i have an s-afc, will the wireing to the ecu be the same as a 00', cause thats what i have directions for
Old 04-28-2004, 10:28 AM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
sedlkfsjd
this thread makes me confusedlkasjdlsdkjsad
sdkfjdljf
Old 04-28-2004, 07:58 PM   #9
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Ludespeed Install Instructions
That's all I know of. As for the AFC, I don't think it will work very good for you, since I think (AFAIK) your ECU will learn around the AFC's adjustments and will have to be reset regularly in order for the AFC to remain effective. You might want to look into a RRFPR with voltage clamp solution, or possibly an E-Manage, Link, etc.
good luck.
jonathan
ilmaestro is offline   Reply With Quote
Old 04-28-2004, 09:56 PM   #10
codyek
Member#: 60558
2003 2.5 rs
midnight blue
hmm. thanks, i have a rrfpr but know voltage clamp. would the grready engine managemet work
Old 04-28-2004, 11:10 PM   #11
PHATsuby
Member#: 13617
2001 Legacy GT back
dont know about the greddy, but i would check and see what type of trigger info your car uses.
go feel the back of your cam sprocket for teeth, if you have two teeth, then you need wrx type engine management, or something with wrx trigger info, if you have 7 teeth, then you are in the clear to use the link plus, Emanage, and others for the old GC's
edit: if your car is a manual you most likely have the wrx triggers, if its an auto you have the old RS triggers.
Ben
Old 04-29-2004, 06:28 PM   #12
codyek
Member#: 60558
2003 2.5 rs
midnight blue
i just talked to forced air tech. they said thier (TMC) is far better for the 02' and up 2.5rs than the s-afc, and 3.5 -4.5 lbs of boost is the max for the newer rs's
Old 05-02-2004, 04:44 AM   #13
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
PHATsuby, so you're saying that a 2002 RS has to use WRX type engine management? I'm in the process of locating a Link Plus and if it won't work this would save me time and money
benjaminetanyahoo is offline   Reply With Quote
Old 05-02-2004, 05:38 AM   #14
PHATsuby
Member#: 13617
2001 Legacy GT back
if you have a manual, then yes i am almost positive you have the same trigger information as a wrx.
the wrx uses a high resolution crank sensor and a two position cam sensor.
the old RS uses a 6 position crank and 7 position cam.
so just go take the right side cover off of your cam sprocket and feel for notches, count those and see which you have.
if this is the case i would look into maybe the 44s or whatever link makes for the wrx if it uses a map sensor. i think the only reason you wouldnt be able to use something like a utec is due to not having a maf system, i thought there were other reasons but i cant think right now.
let me know what you find out!
good luck
Ben
Old 05-02-2004, 05:46 AM   #15
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
hmm this is pretty interesting now, what I don't understand is a Link Plus is universal from what I understand and the notches on my cam sprocket shouldn't matter. We are talking about Link PLus correct? I'm basing this on what I have read at the Link Electro site and talking to the professional installer up in Maryland.
Old 05-02-2004, 06:23 AM   #16
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Please correct me if I am wrong
Old 05-02-2004, 06:34 AM   #17
PHATsuby
Member#: 13617
2001 Legacy GT back
sent you PM, am online as well.
Ben
Old 05-02-2004, 06:41 AM   #18
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Got it, time to figure all this crap out. Well if I can't go Link Plus, then I guess Hydra or a Link for a WRX. Hmmm, but what doesn't make sense is the wiring for the WRX and RS 2002+ are different, so I will have to do all the wiring, what a PITA if this all comes to truth
Old 05-02-2004, 07:00 AM   #19
PHATsuby
Member#: 13617
2001 Legacy GT back
yea how much is the hydra going to cost?
if the hydra uses map that may be the way to go, or if the wrx link does.
how much are each of those?
Ben
Old 05-02-2004, 09:39 AM   #20
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Wow after spending a couple of hours with PHATSuby, I guess 02 RSs can use a Link Plus. Thanks man
Old 05-02-2004, 10:05 AM   #21
PHATsuby
Member#: 13617
2001 Legacy GT back
ok well with the help of Benny we have proven i am misinformed on my info, the legacy manual has wrx info, but not the 2002 manual RS.
so dont worry new school RS owners, you can still use the link plus as it keeps the old style trigger info
Ben
Old 05-02-2004, 10:17 AM   #22
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
No it only applies to me man, screw everybody else, nobody else can buy Link Pluses, why because I need one
WRX parts, 2.5 RS parts and 98 2.5 RS coupe (PA) 69subaru360 Tri-State Area Private Classifieds 13 11-03-2010 12:04 AM
FS: (SoCal) - 1999 I-Speed (X-Wing) 2.5 RS Conversion #10 (1st 2.5-liter AVCS) Delicious Tuning Private Vehicle 'For Sale' Classifieds 6 07-30-2009 02:43 AM
Swap 1999 2.5 RS engine for 2001 2.5 RS engine c0mrade Subaru Conversions 5 06-15-2006 09:19 PM
Used '99 2.5 RS (or) New '02 2.5 TS llam Newbies & FAQs 5 02-20-2002 05:52 PM
