Old 04-27-2004, 06:34 PM   #1
DreddRS25
Member#: 51642
2008 WRX
Question Engine stutters after filling-up?
Nothing major, but when I fill up occasionally my car stutters ever so slightly while at a constant speed. Especially 35-45mph. After a little while or getting on the highway it smooths out and runs great.
Do these symptoms sound like they may relate to a bad/old fuel filter? Anything else?
Any comments or similar experiences do tell, thanks.
DreddRS25 is offline   Reply With Quote
Old 04-29-2004, 06:51 PM   #2
CSM101
Member#: 2805
2001 Impreza 2.5RS
BRP
I have the same problem. Only seems to happen if I run it all the way down to fumes. My fuel filter was changed 20K ago. If I had to guess I'd say it has to do with the fuel pressure differance between a full and empty tank.
If anyone has a better answer or a solution I'd love to hear it.
CSM101 is offline   Reply With Quote
Old 04-29-2004, 06:56 PM   #3
DreddRS25
Member#: 51642
2008 WRX
Yeah it has always been after a complete fillup. Another thing to mention is that the fuel gauge hadn't reached the full-point before I started driving. I'm guessing just a touchy ecu. Thanks for the reply CSM101.
Old 04-30-2004, 12:35 AM   #4
Machine Age Victim
Member#: 29961
2008 Honda Element
1975 Triumph Spitfire
it's your IAC
Machine Age Victim is offline   Reply With Quote
Old 04-30-2004, 12:17 PM   #5
CSM101
Member#: 2805
2001 Impreza 2.5RS
BRP
What is a IAC?
Old 04-30-2004, 12:22 PM   #6
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
Idle Air Controller, IIRC.
DrBoy01 is offline   Reply With Quote
Old 04-30-2004, 01:05 PM   #7
CSM101
Member#: 2805
2001 Impreza 2.5RS
BRP
Not to dis anyone, but how could it be the IAC if it ONLY happens briefly after a fill up? At no other time does it behave odd. It must be something involved in the differance between a empty and full tank.
Old 04-30-2004, 11:07 PM   #8
esbee
Member#: 31858
2005 LGT Wagon
I noticed mine does the same thing after fill-up, but it only seems to happen at speeds around 45 mph like you said. Doesn't last very long though
esbee is offline   Reply With Quote
Old 05-01-2004, 11:09 AM   #9
Machine Age Victim
Member#: 29961
2008 Honda Element
other symtoms of the IAC might not be as noticable
Old 05-01-2004, 11:10 AM   #10
Machine Age Victim
Member#: 29961
2008 Honda Element
yes, it's the difference of fuel pressure supply, I don't know the particulars
'01 RS - Car stutters after filling up HappyEeyore Normally Aspirated Powertrain 12 03-17-2006 01:15 PM
Start up trouble after fill up. mmor101 Normally Aspirated Powertrain 0 10-24-2005 02:27 AM
Car jerks/studders after fill-up DreddRS25 Service & Maintenance 7 03-09-2005 07:24 PM
Dripping fuel after filling up Senger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 11-15-2002 03:46 PM
Why does my car have a strong gas odor after filling up? Eric SS Normally Aspirated Powertrain 2 09-08-2002 02:40 AM
