Old 04-27-2004, 06:18 PM   #1
nyaconis
Member#: 17654
Platinum Silver
Default rocking idle, very low power - details inside! ;-)
All,
I have a MY02 WRX with a few mods -
Turboxs Stage 4 w/ utec and TMI
Spec Stage 2 clutch & plate
Spec lightened flywheel
Rallispec STI V.6 5spd MT
etc.
etc.
Let's cut to the chase -
My Car is running very rough and has little or no power. There is a LOT of engine vibration at idle (especially at idle) and during acceleration the car just seems to really be trying way too hard.
I still have boost (even though it doesn't feel like it) the AF values seem to be in range, I'm not stalling or anything.
I replaced the plugs to see if that was the problem and it did not help.
I also remapped the UTEC w/ the latest software and maps (thanks to my buddy John).
The engine also seems to be noisier, like there is an exhaust leak. I know that my car will feel underpowered if i lost a gasket before the turbo, but the shudder/shaking of the engine has me worried.
I do get cel's popping up here and there which would indicate a misfire, and I probably have a bad coil or something.
Anyone know how I can log the misfires or see what's going on?
-Nate
nyaconis is offline   Reply With Quote
Old 04-27-2004, 06:39 PM   #2
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
You would get a better response putting this in Factory Forced Induction.
Check your compression, to see if you have a beat piston.
-Chav
Chav is offline   Reply With Quote
Old 04-27-2004, 07:05 PM   #3
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
Sounds like how my car ran when one of the wires to the ignitor was cut and the engine was down on 2 cylinders. Rough idle, high vacuum, makes boost but goes nowhere.
Darshu is offline   Reply With Quote
Very, very low idle. Issues galore. beaconhillkilla Normally Aspirated Powertrain 5 03-23-2010 06:27 PM
Running very rough, very low power squeethebee Normally Aspirated Powertrain 14 12-17-2009 11:29 AM
Replaced my battery after 84000 miles, idles very low now... captaind Service & Maintenance 2 07-30-2008 09:05 AM
Car will not rev and idles very low dbridge005 Newbies & FAQs 22 02-28-2007 10:55 PM
very low power oneoverWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-04-2006 10:59 PM
