Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-08-2000, 09:13 AM   #1
Tim K.
Member#: 214
2014 Massey Ferguson
Red
Post Eaton Limited Slip Electronic Differential
Eaton showed a simple electronic limited-slip differential that uses a motor to rotate a ball ramp. This applies pressure to a clutch pack, generating between 0 and 100 percent lockup. Quick response time (0.02 millisecond) means it can be integrated into ABS, traction-control, and stability-enhancement systems. It is very compact and so lends itself to front, center, or rear differential locations.
Tim K. is offline
Old 05-08-2000, 04:09 PM   #2
Joel Gat, 1.8L
Member#: 32
Post
Hello,
More info to be found where?
Joel
Joel Gat, 1.8L is offline
viscous limited-slip rear differential? isn't this inherent in AWD? ufoguy Transmission (AT/MT) & Driveline 9 12-01-2003 11:27 PM
what is viscous limited-slip rear differential? count26 Newbies & FAQs 4 05-10-2003 07:26 AM
limited-slip rear differential = thicker rear sway bar? hunts Brakes, Steering & Suspension 1 04-03-2003 02:27 AM
Limited slip differentials versus electronic slip differential Orson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-16-2002 11:29 AM
Cost to Install Limited Slip Differential? jvogel Normally Aspirated Powertrain 6 02-27-2001 01:21 AM
