Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 01-24-2000, 05:23 PM   #1
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
Question Borla Headers
Do the Borla headers fit MY00 (The ones that fit 98-99)?
Any dyno? hp increase? Anything besides cool sound?
NickSTi is offline
Old 01-24-2000, 05:58 PM   #2
josh
Guest
Member#:
Post
But Plato said we couldn't talk about headers in the tech sect... Oh wait. Wrong Thread.
Nick STi
I am not sure if they fit, but I don't think they changed much on the exhaust side for 2000. So my guess is yes. Apparently Borla dyno'ed them, got about 6hp and 6 ftlbs of torque, and decided to head back to the drawing board. Not sure if that is actually happening, but they are apparently trying to make more power in a newer design. But coupled with a free flowing exhaust, an intake, and a SAFC, the improvements might be even more. There is really no detail on the figures and how they reached them. Imprezer has one on his car, and I noticed a small difference in comparison to my almost identical car without the headers.
I hate to say it, but the sound is the coolest part in my opinion. That's why I am waiting for the second generation, or better yet, getting a turbo.
josh
Old 01-24-2000, 07:33 PM   #3
Joel Gat, 1.8L
Member#: 32
Talking
Hello,
Thanks, Josh But notice Nick asked for tech instead of noise
As Josh said, Borla stopped pushing their headers since they were basically useless. Shiv's dyno-ing came up with really wierd results - +15 hp for the intake and another +5 for the exhaust... Maybe that indicates the bottleneck, post-engine, is at the headers or the cats? Or maybe that indicates that the headers, cats, and exhaust are almost correctly sized.
As for a change in the fit, I don't think there is anything different from '99 to '00 on that side of the engine, so it should fit.
I think.
Joel
Joel Gat, 1.8L is offline
Old 01-24-2000, 08:17 PM   #4
josh
Guest
Member#:
Post
Joel,
Your definanlty on to something concerning the "bottleneck" in our exhaust. I think the bottleneck in our exhaust is at the cats. Has anyone replaced their cats with higher flowing or larger diameter pipe? I have wondered how much, if at all, power would be gained getting rid of the stock cats. The turbo guys open there exhaust a bunch. I would guess for a NA motor the largest you would want to go would be 2.25", cats included. Anyone else thought about this?
josh
Old 01-24-2000, 08:30 PM   #5
Tyrmeltr
Member#: 667
2013 Impreza WRX 5D
Plasma Blue Pearl
Post
I just ditched the cats, simple solution. But I am also turboed so I guess that doesn't count. Would removing cats all together improve performance on a NA car? I assume it would if you were running an EMS, or maybe some ECu band aids (SFC,ITC?). I can't be sure- My NA tuning knowledge is stricly in carburated 2 and 4 stroke motorcycle engines, where EMS and cats don't apply. Any thoughts?
Arik
Tyrmeltr is offline
Old 01-24-2000, 09:15 PM   #6
CM
Member#: 367
98 Impreza RS
(sold)
Post
Will the first cat be hard to get rid of since it is at an angle?
CM is offline
Old 01-24-2000, 11:17 PM   #7
Aphex
Member#: 146
'16 WRX Limited
Post
Stromung sells a "Race Only" pipe that replaces the piece that has the two cats with one (high flow?) cat. it's around $125 or so, can't remember exactly.
Aphex is offline
Old 01-24-2000, 11:57 PM   #8
shiv
Member#: 607
Post
"Shiv's dyno-ing came up with really wierd results - +15 hp for the intake and another +5 for the exhaust... Maybe that indicates the bottleneck, post-engine, is at the headers or the cats? Or maybe that indicates that the headers, cats, and exhaust are almost correctly sized."
My guess is that the stock cat is very restrictive. No testing, just a hunch. It certainly looks terrible. After the intake and cat-back, I think a free flowing cat may be the way to go. I would love to test it. That said, I don't think anyone is going to find much hp in headers. At least not enough to justify its cost (in my opinion).
On the same note, I think it's funny that so many people regarded intakes as being pure "dress up" items. How did that rumor propogate?
shiv is offline
Old 01-25-2000, 12:03 AM   #9
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Hey Arik,
If you ditched your cats, how are you passing CA smog checks?
~Garrick
RidinLow is offline
Old 01-25-2000, 12:12 AM   #10
Joel Gat, 1.8L
Member#: 32
Post
Hello,
Shiv, I never thought intakes were "dress-up." But while balancing power and sound, it's kind of odd that a company like Subaru would kill 15 hp by using a restrictive intake. Yours is barely louder than stock since you have the stock airbox just without those resonator arms and the fender box. Before you say the cheap filter is the cause of the problem, they could have made the plastic box bigger and used a bigger cheap filter. Twice the size would have been twice the flow (so any increase in size would have flowed better and it sounds like they only needed 10% more flow (10% of 165 is 16 hp). There's plenty of room over the ABS in the corner.
The restrictive cat actually makes sense - they were trying to meet some emmsision requirement. The intake was just a silly mistake on their part?
Joel
Old 01-25-2000, 05:15 AM   #11
felix
Member#: 285
1990 legacy wagon L
tan Ugly Duckling
Lightbulb
SHIV TRY GETTING THE DIMENTIONS ON THE EXHAUST PIPE BECAUSE THERE IS A COMPANY called random technolagy that makes a high flow cat that is CARB legal and they can make a cat for our cars.
felix is offline
Old 01-25-2000, 08:37 AM   #12
Tyrmeltr
Member#: 667
2013 Impreza WRX 5D
Plasma Blue Pearl
Post
Garrick...Money, and connections. Don't believe the CARB hype, the system is still very corruptable. AWD Subaru's being dyno exempt makes it easier. My buddy and I actually wanted to see how much my car does pollute. My car passsed the sniff test, no cats and all (I couldn't believe it, and still don't understand it)The visual inspection is stupid. If it paases the dyno, and the sniff test, who the F&$k cares what it looks like under the hood?
If I get a test only notice, I'll buy a junker 98 and smog it. Then do a plate swap. One time I got stopped at an emissions checkpoint, the CHP guy was like "you need to get on this dyno". I said "AWD- Dyno exempt". He looked at book, and told me to go, but said "somethings fishy about this car.. I just know it". This checkpoint was at 9:00 AM on a Tuesday, they were stopping every other car. I feel this is stupid - It created a great deal of traffic congestion (more smog), and MANY people were late to work. I mean if I lost my job becaue of that, I would look for others with the same story, and consider doing some lobbying!
I mean if we really want to cut smog, we need to crack down on SUV's, Diesels, and pre 1973 smog -exempt vehicles. I was so pissed they did that..when I had my 69 camaro, the exemption year was '66. Basically the state of California, while creating tougher regs fo 2000 new vehicles. Allowed 8 more years of cars, to belch as much crap as they want out of there grossly oversized, undertuned engines. Think of all the cars from '66 to '73 - Basically the muscle car era. So you can only imagine what some shadetree is doing to his 'Ol Charger R/T. Just my take on the whole smog thing - Arik
Tyrmeltr is offline
Old 01-25-2000, 10:25 AM   #13
josh
Guest
Member#:
Thumbs up
I would be very interested in seeing a NA car with high flow cats or no cats. My local exhaust guy is willing to weld up a 'test' pipe that would have the O2 bungs, but no cats. THe check engine light would come on, but only because the second o2 sensor is seeing no signifigant change in the exhaust mixture. HMMM.
Shiv, did you get a chance to look at the HKS headers they made for their turbo car? Bigger piping and heat treated. Looks nice, but was curious if you had an opinion on that car. With the turbo set up, do you feel the header is restrictive? or just the cats. You mention that bigger better headers will not yield that much more hp? How are you coming to that conclusion?
josh
Old 01-25-2000, 10:28 AM   #14
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
Question
To think this was just a borla question, but to stray a bit
I thought diesel engines burn cleaner than petrol? Maybe I was wrong but thats why I thought the VW diesel car was so environmental friendly. Feel free to make me look stupid.
But what affects your carb emission level? I want to know cuz I am doing a lot of mods and I don't want to fail the carb test.
NickSTi is offline
Old 01-25-2000, 10:41 AM   #15
Tyrmeltr
Member#: 667
2013 Impreza WRX 5D
Plasma Blue Pearl
Post
I atcually erred, because I don't know anything about diesel impact on smog levels. I'm sure with the proper technology they can be very eco-friendly. Side note- Cool thing about Old VW Diesel Jetta's (A1's), is that they are smog exempt - thereby allowing you to put in a turboed 2.0 16v-very fast, reliable 260 h.p.
I do know however, that when I ride my bicycle and I get whiff of that acrid black cloud, I get headaches and nausea. So I guess I just lumped diesels into my last post, because of the above reason. Might be why alot of new buses are going to methanol or natural gas. Just some thoughts, Later Arik
[This message has been edited by Tyrmeltr (edited January 25, 2000).]
Tyrmeltr is offline
Old 01-26-2000, 08:21 AM   #16
rally123
Member#: 753
Post
Aphex, where did you see the "Race Only" swetup advertised?
mike
rally123 is offline
Old 01-26-2000, 01:26 PM   #17
Bud-Man
Member#: 535
Post
Bud-Man is offline
Old 01-26-2000, 02:22 PM   #18
Danny5
The Emperor Protects
Member#: 13
2014 Chevy Cruze
Diesel
Post
Actually, Diesel engines are a very different animal when it comes to being smogged.
Yes - the put out less of some pollutants than others, but where they really lag behind is particulates. (That black sooty cloud you see)
But particulates aren't really considered bad, even if they look bad and really add to the overall smog of a city.
Danny5 is offline
Old 01-26-2000, 04:54 PM   #19
Joel Gat, 1.8L
Member#: 32
Post
Hello,
Danny, they also add to the Greenhouse effect. Particles sitting in the atmosphere block reflections from the ground, etc. They kind of work like the canopy of a greenhouse. That's a big reason why you never see environmentalists pushing for more diesel mass transportation. It's bad for the environment. But since we all like our cheap grocery store prices, the truckers unions have an easy time convincing politicians not to force diesel into compliance with more reasonable smog laws.
While diesel in and of itself doesn't have to pollute, the HUGE diesel exemption in the smog laws means that cars that don't have to pollute can get away with polluting a lot more than necessary. See almost every single old mercedes on the road - those cars can be tuned to burn clean, but they always have black soot on their backs and stink to high hell.
Joel
Old 06-22-2000, 01:14 AM   #20
ndmorespd
Member#: 1657
2k RSish
BRP
Thumbs down
One of the things you are forgeting about "Particulates," they may cause a small protion of the smog, BUT they also settle out of the atmosphere... Unlike the hydrocarbons etc...
Mike
ndmorespd is offline
Old 06-22-2000, 06:19 AM   #21
nativo
Member#: 157
1998 JDM STIv8 6sp
Rally Blue Pearl
Talking
Here in PR many of us have replaced the factory cats for a generic one and a complete 2.25" pipes after the Borla Headers. The effect of the headers you can feel it after 4,000RPM specially in 3rd & 4th gears. Since there aren't that many options every little HP gain we can get we go for it. Only G-Tech to Dyno every part we can.
So far a '99 RS with JC Sports Intake, JC Sports 2.5" Catback with 2.25" resonator, JC Sports Torque chip, UR Pullie, Borla Headers and 2.25 high flow generic cat with 2.25" pipe G-Techs 138.5hp. One thing the G-Tech can't give you is when that hp is kicking in.
Now a 2K RS (Stock class race car)with Borla headers and high flow cat with 2.25" mid pipe and center pipe and a 2.0" Borla muffler G-techs exactly the same hp.
Both cars saw a drastic change in power once their header was replaced for the factory one although, the lower rpm (1000 - 2500) torque felt stronger.
We are still looking forward to test various 2.25" mufflers such as Stromung, Borla etc. to see if there is any sygnificant change.
We feel that the most significant bottleneck is at the intake manifold. If some of you may recall a message we posted some time ago a known Subaru aftermarket supplier (who cares who it is) sent his 2000 car to a Japan and they dynoed the motor at the flywheel and they were surpriced at the fact that it only yield 150hp. After many checks and rechecks the intake manifold was to be found responsable for such power loss.
So perhaps we should re-aim our efforts for hp and don't giveup. Engine internals could be left alone for now because there is much to be gained from Electronics, Intake and Exhaust...
Gracias,
Efrain N Alers
Nativo Performance
nativo is offline
Old 06-22-2000, 08:45 AM   #22
stewartg2000
Member#: 1570
2009 Impreza WRX
WR Blue
Post
i heard that the new borla headers for the my00 give an increase of 16hp.
stewartg2000 is offline
Old 06-22-2000, 10:31 AM   #23
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Post
I used to run an AWD Honda that also had 2 cats. I burned one out and still passed smog with no problem. I imagine a single high flow cat on our cars would pass the sniff test pretty easily. As for the visual, I've found smog techs really don't pay that close attention. If it looks pretty stock, and passes the sniffer, you're good to go. I had a JDM engine in there as well, obviously the serial number on the chasis was different than the one on the engine, and he never even noticed!
I am real glad I live in Nor-Cal. We do not get hit with those BS roadside CARB tests. What a pain. Don't they have better things to be doing with our tax$'s?
Matt Monson is offline
Old 06-22-2000, 01:10 PM   #24
thepas
Member#: 817
Post
With my Older Ford Lightning Truck, they didn't care if I had a FULL NOS system on it, as long as it passed the sniffer they didn't care!
Kyle
thepas is offline
Old 06-22-2000, 08:38 PM   #25
ravent
Member#: 500
00/+ RS/OBS
white
Post
Shivs "cats" are at random technology right now, unless he asked for them back yet?
ravent is offline
00 RS mods FS cheap:HID'S,gen4 borla headers,Borla catback,+..LI,NY Rick G Tri-State Area Forum 10 06-27-2003 06:19 PM
mini meet: z1 performance / borla headers- originally suffolk co. borla thread Pat L.I. Tri-State Area Forum 14 04-28-2003 08:28 PM
Borla header + Borla cat-back + Random Tech Cat = Teh sexy noise! Fred Zaplitny Normally Aspirated Powertrain 11 04-17-2003 10:21 AM
First impressions of Borla headers/Borla catback Overtime Normally Aspirated Powertrain 14 01-26-2001 06:12 AM
Borla headers + Borla catback from SPO, anyone running this? Andrew General Forum Archive 0 01-10-2001 12:58 AM
