Old 04-28-2004, 02:37 AM   #1
Rex Ruther
Member#: 55484
Cool Did the MBC with Cobb Stage 2 91 octane Accessport
It almost seems like sacrilege, but it is a pleasant surprise in the 0-60 range with the lower gears. I only road tuned it with the Accessport boost display to be about 1 pound over max boost in 4th without the MBC. Haven't noticed decreased drivability issues or thrown a DTC or CEL. It is running about 2 pounds higher in 1st 2nd and 3rd and a worthwhile trade off in safety from my ignorant point of view. Worst case scenario and I get to by a new turbo, engine, or tranny.
Rex Ruther is offline   Reply With Quote
Old 04-28-2004, 04:41 PM   #2
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
...for 15-25hp. Is it worth it?
Same issues apply for a stock car + MBC. Watch PTFB.
mexicanpizza is offline   Reply With Quote
Old 04-28-2004, 05:42 PM   #3
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
PTFB is the main thing to watch out for. Although the reflash runs more boost at part throttle than the stocker, an MBC will still give you a lot more boost at lower throttle position than the reflash. Also listen for pinging, although with 93 octane, I doubt it will be an issue.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 04-28-2004, 10:04 PM   #4
Rex Ruther
Member#: 55484
I need an excuse to get deeper into this project.
Old 04-30-2004, 08:42 PM   #5
abqkid
Member#: 52295
2003 WRX Wagon
total newb q here......what is PTFB?
abqkid is offline   Reply With Quote
Old 04-30-2004, 08:50 PM   #6
03WRXMA
Member#: 35081
2012 WRX
Partial Throttle Full Boost
Basically too much boost from the MBC, without enough fuel to compensate for it.
03WRXMA is offline   Reply With Quote
Old 04-30-2004, 10:29 PM   #7
abqkid
Member#: 52295
2003 WRX Wagon
alright thanks. can you see ptfb with a reflash or not since boost is now intergrated with fuel as opposed to just a MBC?
Old 05-01-2004, 02:06 AM   #8
Rex Ruther
Member#: 55484
With the Accessport, you can see the boost the ECM sees in real time. I have not hit full boost at partial throttle, FWIW.
Cobb Stage 2 AZ/CA/NV 91 Octane vs Perrin Stage 2 91 Octane Jayknux Engine Management & Tuning 8 01-26-2013 06:58 PM
Cobb Stage 2 AZ/CA/NV 91 Octane vs Perrin Stage 2 91 Octane Jayknux AccessPort 0 02-09-2010 06:53 PM
low boost with stage 2 91 octane blue m&m Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-11-2006 07:40 PM
MBC with Cobb Stage 2.5 brandon_bxtr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-13-2005 07:12 PM
Whats the Redline with Cobb stage 2 ECU 03mbpREX Engine Management & Tuning 1 08-11-2003 07:29 PM
