Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-03-2000, 10:17 AM   #1
mjos
Guest
Member#:
Post Shiv..Where did you tie into the fuel return line for the Bell RRFPR?
Shiv,
Did you install the lines for the Bell regulator into the return line by the Fuel Filter or use that real short hose aft the stock regulator. Or, did you use some other spot?
Mine should arrive next week and so I am mapping out where to put it.
Thanks for any help.
Mark
99' RS Turbo
Old 05-04-2000, 03:38 PM   #2
mjos
Guest
Member#:
Question
Shiv??
Old 05-04-2000, 06:14 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I could have sworn he tied in just after the return comes out of the existing FPR. I could definetly be wrong, though I'd go looking through SCC's article at the pics and see if you can't see it there before taking my word for it.
Also, I recall him talking to the guy who made that thing so you might want to call him and ask if Shiv doesn't show up anytime soon.
8Complex is offline
Old 05-05-2000, 09:41 AM   #4
STi Sev
Member#: 2876
99 Impreza
Rally Blue Pearl
Post
guys shiv is in LA right now at a SCC sponsored rally
he'll answer all posts prolly about monday
STi Sev is offline
Old 05-05-2000, 04:51 PM   #5
SKiDaZZLe
Member#: 19
Post
BEGI FPR goes in line AFTER the stock or upgraded FPR.
This should make sense, since it should restrict the flow back to the tank, only when the boost is high (8lbs?).
this way not under boost, it is completely open and does not effect fuel pressure, as it is all done by the W*R. When the boost hits the pre-set amount, the BEGI starts restricting the fuel to increase the pressure.
shiv also stated this in his 300HP disclosure some while back, and i believe it is in the new SCC also.
michael
SKiDaZZLe is offline
Old 05-05-2000, 08:43 PM   #6
mjos
Guest
Member#:
Post
I realize where it goes as far as functionally..I am looking only for where on the return line that Shiv tapped his in. I guess Shiv needs to answer this one
Mark
Old 05-08-2000, 08:55 AM   #7
mjos
Guest
Member#:
Post
Just moving this to the top in hopes that Shiv runs across it
Mark
Fuel smell from the APS inlet supplied fuel return line??? TurboQueef Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-28-2008 05:45 AM
WTB: coolant and oil return lines for vf-39. If not, anyone know where to get these? bl0wnb0xerbabiE Private 'Wanted' Classifieds 1 11-22-2006 02:41 PM
Which line is the fuel return Lo0mis Normally Aspirated with bolt-on Forced Induction Powertrain 3 05-26-2004 01:45 PM
Where did you mount your stanalone/fuel management? wReXeRw Interior & Exterior Modification 0 04-13-2003 06:59 PM
Were to install the Fuel Pressure T for the Defi gauge. WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-14-2002 04:13 PM
