Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 04-28-2004, 11:26 AM   #1
Member#: 10603
2014 CrossTrek XV
Default Tips for Changing Valve Cover Gaskets
My '96 OB 2.5l Auto (235K miles) is spewing oil, and the culprit looks to be leaking valve cover gaskets, (not the oil pump / cam seals this time, thankfully), and before I jump into this job myself (previously had oil leaks fixed by dealer(s)), I was wondering if someone could comment on:
1) What parts are needed? The parts available seem to include more than the left / right gaskets (i.e. small gaskets, plug seals, etc.). Do I need the entire litany, or just the "main" parts?
2) How difficult is this to perform? Having just done the plug/wires, I now know what interference is needed to be removed to simplify that job. Similarly, what is recommended to facilitate the gasket replacement?
arcsound is offline   Reply With Quote
Old 04-28-2004, 04:05 PM   #2
Member#: 35575
'07 Subaru OBS
I'm thinking put it on ramps, and get at it from underneath. There's not really too much in the way. Looks like it's just drain the oil, disconnect the breather hoses, and pull three bolts per side. Covers should come right off. Clean em up, put your new gaskets in, button it all back up and refill the oil.
nunyo is offline   Reply With Quote
Old 04-29-2004, 01:56 AM   #3
Member#: 54523
One little easy to do thing. If you have a torq wrench and a Tech book around, torq all the bolts to spec. Then if it still leaks, the problem might not be your valve cover. BTW, dont forget to put Permatex ( or equivalent ) around the vavle cover Exactly where the gasket is going to be. Have fun!
CatchMyDrift is offline   Reply With Quote
In the middle of changing valve cover gaskets. NEED HELP! OUScooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-02-2010 11:01 PM
Need a couple part numbers for a valve cover gasket job.... silence2-38554 Private 'Wanted' Classifieds 1 12-26-2009 02:58 PM
what is the best way to change valve cover gaskets midnight2.5rs-t Normally Aspirated Powertrain 9 01-19-2007 12:53 AM
hmmm, changed valve cover gasket, hit a 'bump' and now car sputters to death...HELP! 1995LegWag Legacy Forum 7 03-24-2006 04:00 PM
Changing Valve Cover gaskets? Perdue Normally Aspirated Powertrain 5 12-22-2005 02:17 PM
