Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 06-27-2000, 11:05 PM   #1
wolkomir
Member#: 1404
1942 Subaru Imagine
Flat-Black
Question Tranny swap questions
Hello again all,
i have a turbo charged 98 imprexa 2.5 , and have managed to blow up my tranny while 1/4 miling, by the way 13.3 at 107, cool mph!, any way here is the question:
can i swap a 1999 rs tranny in to my 98. if so is there anything i need to do, i think it should be a direct swap, anyone with knolege please let me know asap!, thanks,
by the way if you have a 99 and have had your tranny off maybee you van help too, does the 99 tranny mount to the top of the block with two bults, one which goes throught the starter, and two studs on the bottom, with two nubs half way up the tranny bell housing that fit in to two holes on the block,
thanks for any help guys
jon wolkomir
98 2.5 R.eally S.weey impreza
wolkomir is offline
Old 06-27-2000, 11:11 PM   #2
Member#: 67
1999 Outlasting
the competition.
Post
you might want to call mike shields at www.spdusa.com
he has the wrx trannys they will bolt up and they have a better gearing for a t/c motor
tom@kartboy is offline
Old 06-27-2000, 11:17 PM   #3
wolkomir
Member#: 1404
1942 Subaru Imagine
Flat-Black
Post
i can't afford a WRX tranny, and you need new pres plate and clutch and flywheel setups, as the clutch on all turbo subarus is entirely different using a fixed throw out bearing instead of a diaphram style like our non turbos, need to watch the budget, new stuff from shield would run somewhere in the 5-7 grand price range too much for me.
just need to know if the 99 will fit 98
jon
wolkomir is offline
Old 06-28-2000, 06:26 AM   #4
ravent
Member#: 500
00/+ RS/OBS
white
Post
The hot setup will be Automatic (I know, it is even hard for me to type it). The Sube (even WRX)trannys do not work well with gobs of power. Can you say paddle shifter??? I am leaving home this morning to spend several days with the first one, and don't know what will happen, but will keep the iboard posted...look for a used automatic.
ravent is offline
Old 06-28-2000, 09:01 AM   #5
Joel Gat, 1.8L
Member#: 32
Post
Hello,
I think ravent fell off the deep end. The '99 tranny will fit nicely on the '98 block. The only issue that will arise in that direction (more arise in using a '98 on a '99) is the starter. The '99 tranny expects a stud from the block, through the tranny, onto which the starter is mounted. To fix this issue, I drilled about an inch or so into the tranny to widen the hole through which the stud goes. Then I dropped an allen bolt into the hole (round head fit perfectly and submerged so tranny was still flat against block). The starter now sits on the already existing stud and that allan bolt.
Pat used a different technique, though I don't remember what he did. Either way, my solution took me about 30 minutes to dream up, fetch the bolt and nut from the hardware store, and implement.
Note, our trannies are about as strong as WRX trannies - I know, no one has proven this yet, but WRX trannies blow up their second gears pretty commonly on modded cars in the 280+ hp range. That's why the 280 hp R/RA variety have hardened gearsets. So there is no point to getting a WRX tranny unless it's an R/RA.
And then at that price point, you might as well have Trey build you a custom box which will probably prove to be stronger than an R/RA gearset (much like MRTs and Prodrives sets are stronger than R/RA sets).
Joel
Joel Gat, 1.8L is offline
WRX tranny swap question JWerty1 Transmission (AT/MT) & Driveline 7 02-22-2005 07:29 PM
Tranny swap question? 95 leg greenscoobie86 Transmission (AT/MT) & Driveline 3 11-10-2004 10:53 AM
Legacy Tranny Swap Questions WagonDave Subaru Conversions 5 06-09-2003 05:06 PM
Tranny swap question shipjumper Transmission (AT/MT) & Driveline 0 01-18-2003 11:57 AM
Tranny swap question. dbrown Mid West Subaru Owners Club Forum -- MWSOC 1 10-26-2002 12:08 PM
