Old 04-28-2004, 03:25 PM   #1
blaznc
Member#: 41862
0000 99L 2.2T, dead
93 Wagon 1.8L of fury!!
Default Ludespeed vs FAT
Anyone have an opinion or have experience with Ludespeed or Forced Air? Thanks
Brandon
blaznc is offline   Reply With Quote
Old 04-28-2004, 04:11 PM   #2
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
From the sound of it, if i was doing a kit, i would wait a month or so for FAT. sounds like they might have some cool/good shtuff coming out.
-Eli
squirrelmasta is offline   Reply With Quote
Old 04-28-2004, 09:48 PM   #3
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
well unfortunately Ludespeed no longer makes kits, but i like my kit.
that being said i think FAT prob makes a better kit, better IC design, better turbo, etc. plus Robert is somewhat local to you, i think its a no brainer for you to go FAT.
check them out at www.kastleskorner.com
Ben
Old 04-28-2004, 09:55 PM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
FAT's official website is Forced Air Tech
kastle is offline   Reply With Quote
Old 04-29-2004, 08:25 AM   #5
elstevo
Member#: 58849
2001 Legacy L, Green
like the $ I dont have!!!
Drooooooooool..................................... ......
I would love to have one of those under the hood.
Anyone that has looked at the site notice that all the turbos are only rated at a 70-80hp gain? There has to be some under-rating going on with those.
elstevo is offline   Reply With Quote
Old 04-29-2004, 11:12 PM   #6
import111
Member#: 24447
2010 Evo GSR
GG
the 60-80 hp gain is at 5 psi. The turbos can support much more power than that. the stock 2.5rs motor however can't.
Ryan
import111 is offline   Reply With Quote
Old 04-30-2004, 10:10 AM   #7
elstevo
Member#: 58849
Ok that makes more sense. Personally I hope to get a STI short block and have my heads done and then go for a turbo set up. The long term goal being to be able to hit the 350-400 hp range.
Old 04-30-2004, 01:54 PM   #8
squirrelmasta
Member#: 33445
Cherry Red
IMO i wouldn't do that. No reason for it. you should go turbo first and then the block. other wise you are going to be running 8:1 compression. right now you are at 10:1. With the lower compression a Geo Metro would smoke you if you don't have a turbo on your car. I thought about doing that too. but was told there is no reason to do anything for boost, unless you have boost.
i guess if you want to prep your engine for boost, i would buy the STi block, but don't install it till you get the turbo, and do it all at once. but doing the block first is crazy. Peace.
-Eli
Co-axial vs Components metoo Car Audio, Video & Security 2 06-02-2010 09:15 PM
Avo Vs Fat mozzy12 Normally Aspirated with bolt-on Forced Induction Powertrain 3 06-06-2007 10:32 AM
WTB: Used Ludespeed or FAT turbo kit! gc8impreza00 Private 'Wanted' Classifieds 2 07-04-2005 10:09 AM
Which turbo kit ? AVO vs. Ludespeed vs.ForcedAirTech wighti Normally Aspirated with bolt-on Forced Induction Powertrain 72 09-12-2003 03:19 PM
Ludespeed Stage III VS Forced Air Tech Stage III VS AVO kit Blu25RS02 Normally Aspirated with bolt-on Forced Induction Powertrain 10 07-23-2003 10:56 AM
