Old 04-28-2004, 03:33 PM   #1
Cooljo2.5rs
Member#: 59806
2001 2.5rs
silver with gold pearl
Default 2.5 Backfire problem
my 01 impreza 2.5 keeps on back firing each time I up shift and press the gas petal...it happens aroung 2-3000 rpm shifts, sometimes the check engine light comes on (happened already 4 times this past 2 months) when this occurs. My car farts bad..Any solutions?
Cooljo2.5rs is offline   Reply With Quote
Old 04-28-2004, 03:46 PM   #2
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Do you have some kind of exhaust or intake modification? I believe it is normal for cars with no cats / high flow cats to backfire. Usually the cause is an overly lean mixture failing to ignite, leading to fuel on the exhaust pipe igniting in there. Maybe the presence of a high flow cat/no car makes it more perceptible?
powerlabs is offline   Reply With Quote
Old 04-28-2004, 03:56 PM   #3
orndog
Member#: 34670
2013 No gears!
Saltine American
It's normal for letting off the gas in gear, not for shifting up. No clue as to the cause myself.
orndog is online now   Reply With Quote
Old 04-28-2004, 05:02 PM   #4
obyone
Member#: 16523
What code does the CEL throw? If it's bad enough to throw a code, it could be misfiring in one or more cylinders.
obyone is offline   Reply With Quote
Old 04-28-2004, 05:57 PM   #5
Cooljo2.5rs
Member#: 59806
2001 2.5rs
yes, i have a stromung exhaust, and intake, i bought this car in an auction and i was talking to the previous owner and said that when he changed the spark plugs, one of the wires got stuck and just snapped off. he said he fixed it though but thats b/s. i think he was running on three cylinders, the wire was from cylinder 3.
Old 04-28-2004, 06:00 PM   #6
Cooljo2.5rs
Member#: 59806
2001 2.5rs
i have changed the plugs and wires and checked the timing and all of it is correct
Old 04-28-2004, 07:55 PM   #7
obyone
Member#: 16523
Running on 3 cylinders would run real rough. So pull the code and work from there.
Old 04-28-2004, 08:23 PM   #8
Defiantguy
Member#: 41268
2015 WRX
I get some backfires occasionaly when upshifting. Though I run a track pipe.
Defiantguy is offline   Reply With Quote
Old 04-28-2004, 11:25 PM   #9
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Is it a backfire or afterfire?
-paK +3
Pakin is offline   Reply With Quote
Old 04-29-2004, 12:12 AM   #10
MattDell
Member#: 16803
-paK +3
What I was wondering..
MattDell is offline   Reply With Quote
Old 04-29-2004, 06:02 PM   #11
silver04rs
Member#: 38825
i wish my car would throw flames when i shifted
silver04rs is offline   Reply With Quote
2.0-2.5 swap problems, STARTER & FUEL INJECTOR STUCK ON??? aarongivey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-31-2010 02:16 AM
Cobb 2.5 starting problems psuknak05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 46 04-01-2005 06:11 PM
2.5 idle problem markk26 Normally Aspirated Powertrain 4 10-25-2004 08:58 PM
cobb 2.5 install problem HonduHunter Texas Impreza Club Forum -- TXIC 42 10-04-2004 11:27 AM
'04 STI 2.5 motor problems??? alfriedesq STi Forum Archive 5 01-19-2003 02:18 AM
