Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 09-05-2000, 06:10 PM   #1
STORER
Member#: 2253
2000 2.5 RS
Red
Post 18mm Rear Antisway bar
I'm looking for an 18mm rear antisway bar. The only thing I can find is 20mm and 21mm. Any leads?
STORER is offline
Old 09-05-2000, 06:11 PM   #2
Subu WEX
Member#: 1169
Post
JCSports has an 18mm bar.
http://www.jcsports.net/
Subu WEX is offline
Old 09-05-2000, 06:21 PM   #3
tmaler13
Member#: 1992
Lightbulb
SPD Tuning has them too. www.spdusa.com
tmaler13 is offline
Old 09-05-2000, 06:38 PM   #4
Overtime
Member#: 1346
Post
Teague's Auto. www.teaguesauto.com
also, try TRi Tuning. 18779TUNING
Overtime is offline
Old 09-05-2000, 06:52 PM   #5
jImp
Member#: 1741
1999 Impreza 2.5 RS
Rally Blue (Sold)
Post
Hey, why don't you get a whiteline adjustable bar. Then you can keep it at 18, and then adjust it to your preferance.
jImp is offline
Old 09-05-2000, 08:07 PM   #6
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Post
Check with rallispec to get the Whiteline.
ZEE
Sunrise City Rider is offline
Old 09-05-2000, 10:46 PM   #7
NightmareOnSubySt
Member#: 1352
2005 Forester XT
black
Post
Get the 20mm or larger adjustable. The 18mm will have you looking for "more bar" before you know it!
NightmareOnSubySt is offline
Old 09-06-2000, 08:21 AM   #8
AllWheelsDriven
Member#: 1737
2005 BMW zhp
www.vispoint.com
Post
I got a 20mm bar and its a world of diff with the stock suspension and much better tires
AllWheelsDriven is offline
Old 09-06-2000, 05:28 PM   #9
Ken Levin
Member#: 1416
2/01 WRX SportWagon
Question
I just installed Ground Control AGX/Eibach adjustable setup on my 5-door. I have an 18mm rear bar. How will changing to a 20mm affect the handling? From the above it sounds like the way to go. Why?
In any case, I may have an SPD 18mm bar for sale.
[This message has been edited by Ken Levin (edited September 06, 2000).]
Ken Levin is offline
Old 09-07-2000, 09:15 AM   #10
DuneHopper
Member#: 1249
2000 OBS
Exclamation
Do a search on swaybars, and you will find many discussions on the pro's and con's of bigger swaybars.
I totally recommend using a bigger bar than stock, vast improvement in the car's handling, but...
In short, 18 mm bar is recommended for stock suspensions, 20 mm (or more) for stiffer suspensions. The problems with the bigger bar are in inclement weather. In the rain or snow, the back end may slide out too easily. If you search, you'll find many warnings (and some wrecks) about using a big bar in bad weather.
DuneHopper is offline
Old 09-07-2000, 05:47 PM   #11
Ken Levin
Member#: 1416
2/01 WRX SportWagon
Post
Thanks DuneHoppper. I should have thought to search; it's a great feature of this site!
(FS) Cusco rear antisway bar, 22mm, 05 STi aaaacccc Suspension/Brakes/Handling 3 01-03-2009 12:02 PM
FS Locally: 18mm Rear Antisway Bar 25psi Tri-State Area Forum 6 10-29-2002 08:30 PM
Cusco 18mm rear Sway bar on BE5 review. Jason Legacy Forum 0 11-11-2000 06:05 PM
18mm rear sway bar for sale SCRAPPYDO Southern California Impreza Club Forum -- SCIC 0 10-17-2000 03:51 PM
18mm Rear Antisway Bar STORER General Forum Archive 2 09-04-2000 04:33 PM
