Old 04-28-2004, 07:07 PM   #1
nhalterman
Member#: 12120
'05 Legacy GT
'99 2.5 RS
Default Multiple Miss-Fires
Okay here is my situation. Please let me know what you think.
The car has 64,000 miles on it.
My car is idling bad, it has a horrilble hesitation anywhere under 3200 RPMs at 1/4 throttle, and the car backfires. If I punch the throttle, the car takes off. If I'm above 3200 RPMs I have do not have hesitation at any thottle position.
The car starts to run slightly better once it has warmed up.
I went to Autozone and I pulled the following codes.
Miss-fire in 1
Miss-fire in 2
Miss-fire in 3
Miss-fire in 4
02 error bank 1 P01301 (probably just the header)
Under a year ago I had my coil replaced.
I replaced my plugs and wires under a month ago.
I replaced my fuel filter under a month ago.
I have never replaced my 02 sensors.
The car has:
Cobb intake
Borla header
Stromug Mid-pipe
Scooby Sport Axle back
Perrin Pully
(various suspension & brake upgrades)
I went to a track day at Mid-Ohio last year and my coil went bad. I had it replaced. I went to Mid-Ohio again this year, and the problems started again, but this feels different from last year. I didn't have idle problems last time, and it felt more like hitting the Rev limiter at 3000 RPMs last time. This has a different feel.
I'm guessing it's the coil again, or possibly the O2 sensor.
Please give me your input. Thank you.
nhalterman is offline   Reply With Quote
Old 04-29-2004, 01:05 PM   #2
C-daleRidr
Member#: 18074
2008 Speed3
How's your coolant?
C-daleRidr is offline   Reply With Quote
Old 04-29-2004, 04:34 PM   #3
nhalterman
Member#: 12120
'05 Legacy GT
'99 2.5 RS
I replaced that before the track day as well. It's less than a month old. I checked the level as well. It's a nice Subaru coolant green too. So I'd don't think it's a head problem.
Thanks.
Old 04-30-2004, 12:32 PM   #4
obyone
Member#: 16523
May sound stupid but did you check your plug wires to see if they are properly seated?
I just had a CEL for misfire in cyl. 1,2, and 3, after getting my TWE cams installed by the dealer, and it turned out they didn't properly seat my plug wires onto the plugs. They were loose on 3 out of 4 cylinders.
obyone is online now   Reply With Quote
Old 04-30-2004, 05:45 PM   #5
nhalterman
Member#: 12120
'05 Legacy GT
'99 2.5 RS
I have had that problem before. I didn't torque my plugs down enough so the wires didn't seat. I fixed that and reset my ECU. So this a different problem.
Thanks though.
Old 04-30-2004, 06:33 PM   #6
obyone
Member#: 16523
Thanks though.
More stupidity, did you check the plugs to see if they still fire?
Old 04-30-2004, 07:40 PM   #7
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
I would vote ecu
Honkey3k is offline   Reply With Quote
Old 04-30-2004, 10:50 PM   #8
CheezeWeezle
Member#: 17187
2009 Braun Entervan
Gimpy White
Originally posted by Honkey3k
I would vote ecu
That's a possibility...a scary and $$ one too.....An O2 sensor wouldn't cause misfire codes on all cylinders though...not in my experience anyway...That and I wouldn't think you would be able to punch it with a bad O2 as well....maybe it's your coil again? Doing a quick once over of the RS service manual; It may be your injectors or a poor connection for the injectors..
CheezeWeezle is offline   Reply With Quote
Old 05-01-2004, 10:42 PM   #9
obyone
Member#: 16523
Well...didja?
Pull the plugs and leave the wire connect to it. Then touch the thread part to a ground and start the car.
"IMPORTANT TO DISABLE THE OTHER WIRES SO THE CAR DOESN"T START ON YOU!"
Old 05-03-2004, 01:54 PM   #10
nhalterman
Member#: 12120
'05 Legacy GT
'99 2.5 RS
Thanks. I didn't try this simply because this problem doesn't happen all the time. So the spark plugs must be firing most of the time. I don't think that this would tell me much.
If I had a constant miss-fire, then this would be a good test. Or am I wrong? Thanks anyway.
Well...didja?
Old 05-03-2004, 01:56 PM   #11
nhalterman
Member#: 12120
'05 Legacy GT
'99 2.5 RS
Cheeze,
Yea, I hope it's not the ECU.
What experience do you have with bad O2 sensors?
I'll run some injector cleaner through it, and check all of my injector wire connections and wires for burn marks.
Thanks.
Old 05-03-2004, 08:14 PM   #12
CheezeWeezle
Member#: 17187
2009 Braun Entervan
Gimpy White
With other cars I have had when the o2 sensors went bad I couldn't accelerate at all, and actually it idled fine.......It would sputter and run like pure hell. Like I said, The service manual suggests either your coil, or injector problems..
Old 05-03-2004, 11:28 PM   #13
obyone
Member#: 16523
You never know, but it's always best to rule out the least expensive fixes caus you don't wnat to spend alot of coin to fix something that would've been a few bucks to replace.
Old 05-04-2004, 09:32 AM   #14
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
What plugs did you put in?
What wires did you put on?
Old 05-05-2004, 02:37 PM   #15
nhalterman
Member#: 12120
'05 Legacy GT
'99 2.5 RS
Stock plugs & wires
Old 05-05-2004, 04:25 PM   #16
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
Interesting, awhile back i had uneven idle and misfire on all cylinders and the same code you had. Car would hesitate terribly at low rpm's but once past 4grand it would do fine and everyone said it wasn't an o2 sensor........three aggregating months later I stop listening to every body and got a new o2 sensor and the problem was solved.
maybe its just me
Burnout is offline   Reply With Quote
Old 05-05-2004, 07:39 PM   #17
CheezeWeezle
Member#: 17187
2009 Braun Entervan
Gimpy White
doesn't hurt to try...
Old 05-05-2004, 09:32 PM   #18
maddbmxjumper
Member#: 43044
01 sedona red ej20
stage 3 vf23 rs
ill put $$ on the rear 02 sensor, i had a cel, and i went to auto zone i it was same codes, missfire on all cylinders, and i took it to my subaru dealership and it was the rear o2 sensor, the 02 sensor is not covered under warranty so they replaced my cats so that it would be under warranty, ha ha, but ill bet its the 02 sensor, the rear one, kyle
maddbmxjumper is offline   Reply With Quote
Old 05-05-2004, 10:56 PM   #19
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
The front is the one that crapped on me. The rear is to make sure the cats are operating correctly.
Old 05-06-2004, 02:48 AM   #20
joefocker20
Member#: 13745
2015 STI
I'd send the injectors to RC engineering to have them cleaned and flow tested. If not, buy new ones. I'd also ditch the OEM Crapion plugs and get some NGKs. Is there a way to check our coils with a multimeter? I had a fuel filter that was ruined by ****ty gas once, and it did the same thing, but that's an odd occurence.
BTW: the Rear 02 sensor does jack..
joefocker20 is offline   Reply With Quote
Old 05-07-2004, 04:02 PM   #21
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
I would find someone local and see if they wouldn't mind switching out sensors for a little bit. Its not hard to do. I think there's a place online that sells the bosch o2 sensors for like 30 bucks. Another way to test it I think would be to unplug it and the car should go to a set map and see if the problem still occurs, if it goes away you know what it is then. Don't quote me on that but its worth a try and its free. Every one told me it was the wires, plugs, coil, water in my tank fuel filter the list went on. The o2 sensor is funny like that and a damn pain.
Old 05-07-2004, 06:02 PM   #22
obyone
Member#: 16523
Carefull with the O2 sensors. They are made of soft metal and will strip if you force them.
Old 05-10-2004, 11:04 AM   #23
nhalterman
Member#: 12120
'05 Legacy GT
'99 2.5 RS
Thanks for everyone's help.
I'm betting on the O2 sensor now.
I went to an auto-x on Sunday. The car was so rich that it stalled at idle. My gas mileage is way down right now too.
The only plus was that when I launched it spit black soot all over the front bumper of an Integra behind me. j/k I felt bad it was a nice Type R too.
I'll put an O2 sensor in this week and let you know how it goes.
Thanks again.
Nathan
Old 05-10-2004, 12:29 PM   #24
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
rich huh? could be Temp. Sensor.
1 Lucky Texan is offline   Reply With Quote
Old 05-10-2004, 02:49 PM   #25
obyone
Member#: 16523
My car has a CEL for misfire too, but my O2 sensor is literally a week old.
miss fireing all 4 spidermanswrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-03-2004 12:11 PM
Miss fires at near start up WrxRacer305whp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-27-2004 09:32 PM
Miss fireing STUDAndring Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-22-2004 04:54 AM
miss fire wavecruzer79 Mid West Subaru Owners Club Forum -- MWSOC 0 05-13-2003 04:04 PM
Cyl. Miss-Fire racinready300ex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-05-2003 06:31 PM
