Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-05-2000, 10:14 PM   #1
Member#: 587
Post Air / Fuel meter installation (HELP!)
First off, i suck with electronics. i just got an air fuel meter for my 2000 rs. the red wire goes to power, the blck goes to ground, and the violet goes to oxegen sensor wire, not exactly at the oxegen sensor, but after the connector. anyone know which wire, there are 4. 1 grey
1 red/yellow
1 blue/black
1 white/black
Dane is offline
Old 05-05-2000, 11:20 PM   #2
Member#: 899
Hi, what kind of meter do you have? The correct diagrams for hookup are at www.lagging.com . I believe you need to tap into the ECU for the rear O2 sensor. There are 2 O2 sensors on the MY00, and the front one is a non-standard voltage, the rear is standard from 0-1volt output.
According to the diagram, the wire you want to tap would be no.18 on terminal B136. Now, I haven't done this yet myself because I am still in the process of getting an a/f meter, but this is what I would use.
Also, others have noted that because the second O2 sensor is a bit further back, you should add a couple of bars to the reading (if you have an autometer guage) to get a more accurate idea of what's going on.
Good luck, and let us know how it works out.
pilotdoc is offline
Old 05-06-2000, 01:29 PM   #3
Member#: 788
1989 GMC 1500
Could you or anyone explain or recommend a site that talks about a/f ratio and bars?
I have a SAFC and want to know how to tune it using the 02 sensor monitor. I've heard that .87 is a good reading, what if its lower or higher. I don't want to lean out my engine too much.
Any help would be appreciated.
Max is offline
Old 05-06-2000, 04:38 PM   #4
Member#: 329
1995 325i
Arctic Gray
Can an EGT gauge serve the same purpose as an A/F gauge?
RidinLow is offline
Old 05-07-2000, 02:26 AM   #5
Member#: 899
I'm not totally sure, but I was told by a mechanic that an EGT can be even more accurate for tuning than an A/F guage. You need to mount the sensor close to the engine though, like in the headers.
pilotdoc is offline
Old 05-07-2000, 02:30 AM   #6
Member#: 899
Woohoo, I'm a specialist now!
Max, AFAIK, the bars refer to the LED bars in the guage, which light up sequentially according to the meter's reading. I think there's a bunch, maybe 30? divided into sections of red (lean), yellow (stoich), and green (rich).
The thing with the O2 sensors is that they are especially sensitive over the stoich area, so that all of the yellow ones are in a very narrow range, but when you get into red or green, there's more of a difference in voltage needed to produce a change.
I don't actually have the meter, so maybe someone who does can clarify any misinformation I've just posted under my new title of "specialist" (indeed!)
pilotdoc is offline
Old 05-07-2000, 11:47 AM   #7
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
An egt gauge can give you some of the info that an a/f ratio gauge gives you, but they are (obviously) measuring different things. The O2 sensor is going to give you a direct measurement of the current (well, a second or so ago) mixture, and they do a good job if you are pretty near 14.7:1. An EGT will give you the exhaust temps, with higher usually meaning leaner and lower meaning richer, but they will only reallly give you an idea of the mixture at wide open throttle.
rao is offline
air/fuel gauge install help trevman2 Alaskan Impreza Club Forum -- AKIC 14 06-08-2004 08:40 PM
Air/Fuel Meter correct install? V8ETR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-24-2002 10:19 PM
Need Help Installing Autometer Air / Fuel Meter STi PWR Normally Aspirated Powertrain 4 05-15-2002 06:27 PM
air fuel TT install HELP SeattleWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-28-2001 04:33 AM
air/fuel meter wiring help inpreza kid Normally Aspirated Powertrain 32 01-24-2001 07:57 PM
