Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 03-14-2000, 11:48 PM   #1
U-R-A-BUS
Member#: 516
Question AFC o2 Sensor
I have my APEXi S-AFC blue wire, hooked to my first o2 sensor. I go to sensore check, watch the voltage on #2, the thing jumps from .001 to 1.00 and every number in between. I know the voltage isnt a great way to monitor the o2 but this is impossible...
See ya
U-R-A-BUS is offline
Old 03-15-2000, 05:39 AM   #2
HRE | giulio
Member#: 481
Lightbulb
I think that sounds right. To use the AFC to monitor the O2 sensor, you need to take readings at WOT (wide open throtle).
g
HRE | giulio is offline
Old 03-15-2000, 06:19 PM   #3
Gadzuks
Member#: 433
Smile
The voltage at Idle should jump around,if it's running like .1 to .2 solid at idle it's to lean. At wide open throttle while accelerating it should try to stay around .9 to .94 for a good even fuel burn.
Gadzuks is offline
Old 09-17-2000, 10:10 AM   #4
2yLiTe
Member#: 660
Post
Is this true? .9s at WOT? every other post I've read says .85 to .87...what gives?
And is it the higher the value...the leaner? or the other way around?
2yLiTe is offline
Old 02-02-2001, 07:20 AM   #5
Gambit
Member#: 102
Post
When u mentioned WOT, can you be in neutral or the car must be going to get the reading?
Gambit is offline
Old 02-04-2001, 11:18 PM   #6
Tony_Chen
Member#: 3983
2000 Impreza Rs2.5
white
Post
Does anybody knows how to setting S-AFC in Impreza RS2.5 year 2000, I am setting S-AFC in Pressure 07 sensor(is it ok?) and I don't know the HI-Thrtl and LO-Thrtl setting,can someone give me some advice?
thanks a lot.....
Tony_Chen
Tony_Chen is offline
Front O2 sensor vs Rear O2 sensor (MY00 RS) Jewbaru Service & Maintenance 3 07-29-2012 10:14 PM
FS (OH): WRX/STi rear o2 sensor, MAF sensor, MAP sensor coolblue05 Engine/Power/Exhaust 14 07-07-2009 02:52 PM
How is the S-AFC related to the O2 sensors? Robmat Engine Management & Tuning 3 07-05-2003 12:33 PM
O2 sensor problem w/S-AFC and A/F ratio gauge Scoobyslack1 Normally Aspirated with bolt-on Forced Induction Powertrain 6 09-05-2001 03:38 PM
help..S-AFC Blue wire O2 sensor?? tmaler13 Technical Forum Archive 14 09-11-2000 06:20 AM
Message Board Statistics All times are GMT -4. The time now is 02:53 PM.
