Old 04-28-2004, 10:07 PM   #1
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Question The WRC 4WD System
I'm wondering if the WRC cars uses the 4WD system on the tarmac stages?
I understand back in the Group B days, the cars would spin and slide like crazy (controlled) on the corner because of thier lock.
Are the 4WD systems the traditional ones we see today on SUVs? Or are they designed differently and allow the system to differentiate speeds via driver control (maybe like DCCD?)?
Thanks,
-paK +1
Pakin is offline   Reply With Quote
Old 04-28-2004, 10:20 PM   #2
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
They still use 4wd on tarmac. The differentials are very advanced and Electro-hydraulically controlled. Not anyting at all like an SUV
They slide around hairpins by pulling the handbrake which then locks rear wheels and opens center diff.
DonA is offline   Reply With Quote
Old 04-28-2004, 10:35 PM   #3
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Ford built their belated Group B RS200 with a shift on the fly 2WD/4WD system. The concept was that they'd use 2WD on tarmac events, and 4WD on gravel/snow.
The cars were just as fast in 4WD on tarmac as they were in 2WD, so most of the cars had the levers removed.
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 04-29-2004, 01:59 AM   #4
nKoan
Member#: 38189
05 Legacy GT
Garnet Red Pearl
Yup, the AWD system works just as well on tarmac as on gravel.
The system is way more advanced then almost anything available on a production car. Every WRCar (except the new Lancer WRC) uses active differentials, which can actively send power to the wheels that need it before any major slippage occurs.
In fact, the only reason F1 doesn't use AWD is because it is banned (it was banned due to saftey issues IIRC... driveshaft being literally inches away from drivers butt and spinning up to 12k rpm).
nKoan is offline   Reply With Quote
Old 04-29-2004, 09:33 AM   #5
jmott
Member#: 6713
2007 Prius
brown
do they?
you have seen this?
jmott is offline   Reply With Quote
Old 04-29-2004, 09:35 AM   #6
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
Don't you get Speed Channel? If not, bitch to your local cable company...
heffergm is offline   Reply With Quote
Old 04-29-2004, 01:55 PM   #7
nKoan
Member#: 38189
05 Legacy GT
Garnet Red Pearl
Originally posted by jmott
do they?
you have seen this?
Yeah, WRC drivers do it all the time. If you watch any of the tarmac rallies, you'll notice from time to time the rear wheels will lock up and the front ones will keep spinning while sliding around a hairpin. The only way to do this is to disconnect the center diff, otherwise it would be utterly destroyed with the back wheels locked up and the front wheels spinning.
Old 04-29-2004, 02:02 PM   #8
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
This I can acknowledge. Sounds valid.
Thanks for the replies everyone.
-paK +3
Old 04-29-2004, 02:18 PM   #9
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
they did have some AWD F1 cars in the late 60's early 70's. The werent fast enough, but one almost won a race in the rain before crashing.
i love this website
http://www.ddavid.com/formula1/story...0Wheel%20Drive
AndyRoo is offline   Reply With Quote
Old 04-29-2004, 02:56 PM   #10
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
Here is some video of the 2002 season that shows a little tarmac fun http://www.rallyplanet.com/media/mov...wrc-2002-1.wmv
BTW - The Citroen Xsara was once a 2wd entry only run in select tarmac events. They domated so much they outraged the World Rally teams to the point that the FIA made rules more rigid for the F2 cars. Citroen built a new turbo charged 4wd WRC the Xsara T4.
Old 04-29-2004, 06:41 PM   #11
nKoan
Member#: 38189
05 Legacy GT
Garnet Red Pearl
i love this website
The AWD cars were technically banned due to a saftey argument IIRC. I think it was because of a driveshaft being literally inches away from a drivers butt, and spinning at 12k rpms.
I really wonder if the AWD F1 cars could have ever become as competitive as the RWD ones.
Old 04-29-2004, 08:01 PM   #12
GravelRash
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
You can also see occasional shots of them pulling the handbrake on tarmac hairpins, just like on gravel.
GravelRash is offline   Reply With Quote
Old 04-29-2004, 08:21 PM   #13
digitalpimp
Member#: 40931
05 sport wagon
group 2 96 gti
once utech was talking about driving a car with the totally active centerdiff, he said on corner entry it felt like a rx-7 (i'm fairly sure he said rx-7). i'd assume they actually open the centerdiff under heavy braking (or even engine decel?) to promote oversteer. on doug's #88 car i made a (crappy) bracket for the ebrake microswitch so the computer knows when the brake is on, but i believe he said it still didn't work (sorry doug).
a person could have the computer know when the brakes are on, ebrake is on, clutch is in, individual wheel speed, and the throttle %, so those are all imputs that could be used to decide how to control the center diff.
digitalpimp is offline   Reply With Quote
Old 04-29-2004, 08:39 PM   #14
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
adding to yours...
The computer that controls the AWD system is quite advanced to a degree that is unknown to me. It collects data from various sensors around the vehicle such as yaw, g's, steering, wheel speed, and a few others and it electronically applies it's hydralic system and power the wheels that is designated to with those calculations from the sensors.
Ex.
Steering right, applying throttle will send 50% of torque to the rear outside tire and 25% to inside and 12.5% to both front wheels. Steering straight after the turn may then distribrute 65%rear and 35% front.
Ex.
If sliding/overteering out of a corner after the turn from the previous example, the yaw and G sensors will take those calculations and go from 50% of torque to the rear outside tire and 25% to inside and 12.5% to both front wheels to 25% all around OR 12.5% rear tires and 50% outside front and 25% inside front tire to pull out of the drift/slide.
This is done with the hydralic diffs.
That's my knowledge of this AWD system. Someone can correct or comment if wanting to.
FuJi K is offline   Reply With Quote
Old 04-30-2004, 11:43 AM   #15
donmei
Member#: 55101
2004 STI
FYI - STI center diff opens when ebrake is pulled. I discovered that this winter.
Don
donmei is offline   Reply With Quote
Old 04-30-2004, 12:26 PM   #16
SleeperWRX
Member#: 8179
You can pull the ebrake to lock up the rear wheels on a WRX and it doesn't lock up the front wheels. Yes this is bad for the diff...but its not impossible...and I've done it dozens of times. Something prolonged like towing the car on 2 wheels would of course destroy the center diff.
SleeperWRX is offline   Reply With Quote
Old 04-30-2004, 02:52 PM   #17
Calimoxo2
Member#: 34531
'84 1/10 BRAT
Red
do they?
you have seen this?
Last year Carlos Sainz did one and followed it through with a dual 360 on tarmac in a Focus.....
Calimoxo2 is offline   Reply With Quote
Old 04-30-2004, 03:50 PM   #18
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
What event was that? Are you thinking about Gilles Panizzi's little spin show at the 2002 Rally Catalunya in the Peugeot 206?
Old 04-30-2004, 05:13 PM   #19
nKoan
Member#: 38189
05 Legacy GT
Garnet Red Pearl
Carlos drove for Citroen last year. I think you are thinking of Panizi at Catalunya in 2002 in a Peugeot 206.
Old 04-30-2004, 06:36 PM   #20
Impreza01
Member#: 152
2002 Impreza WRX
I hate to be the person who buys your car when you sell it.
Impreza01 is offline   Reply With Quote
Old 05-01-2004, 12:48 AM   #21
meåtåd
Member#: 60892
So what exactly is the benefit of the rally cars using 4WD over AWD? Correct me if I'm wrong, but from the things I've read, 4WD locks all 4 wheels at the same speed where as AWD varries them.
meåtåd is offline   Reply With Quote
Old 05-01-2004, 04:49 AM   #22
nKoan
Member#: 38189
05 Legacy GT
Garnet Red Pearl
If you want to draw that distinction, I believe that WR cars use AWD because the power to each wheel is constantly changing.
Old 05-01-2004, 08:55 AM   #23
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
Right but in the sport it is generally referred to as 4wd when I guess you could technically call it AWD
Old 05-01-2004, 09:20 AM   #24
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
center diff < transfer case... but essentially the same thing. Both divert power to the other set of wheels. Most AWD cars are FWD layouts with center diffs sending power to the rear, most 4WD cars are rwd with a transfer case external to the tranny sending power to the front via a separate external driveshaft at a set (locked) ratio. Again, basically the same thing... its more semantics.
Old 05-01-2004, 06:53 PM   #25
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
I bet it would be today... but the big teams simply won't put the R&D in it i would say. It would take time for it to be competitive... simply because of the advancements of the RWD cars today...
HOK is offline   Reply With Quote
BMW 325iX - what type of AWD/4WD system newscooby Off-Topic 25 03-30-2006 10:58 AM
So nice to test your 4WD system.... 4x4GGG Off-Topic 30 12-10-2005 11:07 PM
Anyone familiar with the 4WD system on a 1990 Legacy? solo2wrx Legacy Forum 4 08-28-2005 05:30 AM
WRC intake system In2Deep Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-02-2002 08:22 PM
On the WRC cars, is there a misfiring system? GTBGUY Technical Forum Archive 11 10-06-2000 01:07 AM
