Old 04-28-2004, 10:45 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default Bad injector rings
I recently put 270cc injectors in my EJ18 turbo. I would say, a few days later I had an injector ring go bad on one. I replaced that with ring from one of my 370cc injectors. Then a few days later, that same ring went bad. So I replaced that one with one from my 180cc injectors. Then tonight I had that ring go bad.
I'm starting to think that it's not the rings. What could be causing the rings to go bad the way that they are. Thanks for the help, as always.
Brent
scoobyimprza is offline   Reply With Quote
Old 04-29-2004, 12:54 AM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Try using some silicone based lube when you put them in. Might be rolling them up some when you put them in.
Drac9 is offline   Reply With Quote
Old 04-29-2004, 01:17 AM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Thanks, I'll lube 'em up good. What if I put 2 rings on it?
Old 04-29-2004, 01:20 AM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
also chjeck for burrs
Old 04-29-2004, 01:24 AM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Burrs where?
Old 04-29-2004, 01:25 AM   #6
Unsung Boxer
Member#: 37196
dont use silicone lube, use what is called "rubber grease" you can find it at any auto supply store.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 04-29-2004, 01:41 AM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
whats wrong w/ silicoen?
Old 04-29-2004, 02:51 AM   #8
Unsung Boxer
Member#: 37196
silicone is considered a contaminant as it will not be eaten by oil or fuel.. it is not recommended to use silicone on the fuel system, as it can get caught in an injector. Ive heard that its also not good to end up in the valves either. At any rate, rubber grease is a better lubricant for injector rings
-Jake
Old 04-29-2004, 03:09 AM   #9
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
those silicone hoses have to degrade and send silicone into the enginetho
Old 04-29-2004, 03:17 AM   #10
Drac9
Member#: 9861
Interesting. I had not heard that. I used it on mine and have not had any problems over 30,000 miles. Not to say i wont. I didn't put a ton on there though and the stuff i used was pretty sticky.
CYL 4 Bad Piston Ring? ec2k1gt Built Motor Discussion 2 09-27-2007 10:15 PM
stock wrx parts, turbo,IC,injectors, ring and pinion gotti Private 'For Sale' Classifieds 17 01-31-2006 11:04 AM
bad Injectors? imprezavness Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 05-31-2004 01:19 AM
willing to sell your BAD injector adapters? PHATsuby Normally Aspirated with bolt-on Forced Induction Powertrain 10 06-23-2003 01:41 PM
bad injector? Onederer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-24-2002 06:59 PM
