Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-04-2000, 04:07 PM   #1
the spacecowboy
Member#: 765
Post those who have the $10 intake mod
i finally got a chance to do this intake
now to me it doesnt feel like i got and increase in power or acceleration
i probably wouldnt know either so im wondering how i could tell if i actually got more power or not being the stupid newbie i am
also i ordered a amsoil filter and its going to take 4 weeks before i recieve it
will i know then if i got more power?
thanks,
ThE sPaCeCoWbOy
the spacecowboy is offline
Old 05-04-2000, 10:29 PM   #2
larryganz
Member#: 1061
2004 STi Blue/Gold
Wife made me downgrade...
Post
Did you reset your ECU? I got an improvement after doing that.
Disconnect battery overnight and let engine cool off. In the morning reconnect the battery, and be prepared for alarm to sound off and turn it off with remote. Put key in ignition and turn key till idiot lights turn on and stop there, wait two seconds for fuel pressure to come up, and turn key to start engine without touching gas pedal. Let car warm up over about 15 minutes, usually till electric cooling fan comes on (might not though). Once engine warm shut off.
Restart car and drive off demonstrating all styles of driving over the next 20 to 30 minutes, fast, slow, low revs high revs, etc... This will help retrain the ECU.
You might as well wait to do this till you get your AMSOIL filter installed.
One thing you should know, not only do you get more air flow, but the Fuel injection system compensates with more fuel and mileage may suffer. And, the colder the air gets, then the more fuel you use because the temperature sensor will increase fuel supply even more. Expect a 15% drop in fuel economy without an APEX AFC to adjust the Air Fuel ratio.
Larry Ganz
www.ImprezaRS.com
larryganz is offline
Old 05-05-2000, 12:06 AM   #3
the spacecowboy
Member#: 765
Post
ok i did diconnecte the battery and let the car sit for 15 minutes and the different driving styles
i didnt wait for the 2 seconds and never shut off the car after the 15 minutes
i guess i'll do that when i get the air filter
can i drive it around the way it is or do i need to add the intake boxes back on?
thanks,
space
Old 05-05-2000, 02:15 PM   #4
pilotdoc
Member#: 899
Post
What exactly did you do with the intake? I'm guessing that you're still using the stock panel filter. If so, you may not see much performance gain with intake modification til you get a performance filter (K&N or Amsoil).
During ECU reset, you have to start engine, idle for 15-20 min, until the fan cycles, then turn it off, all without ever touching the gas. Then restart and drive around etc.
pilotdoc is offline
Old 05-05-2000, 05:16 PM   #5
larryganz
Member#: 1061
2004 STi Blue/Gold
Post
I saw an improvement with my cold air intake mod, before I got my AMSOIL filter, by doing the reset as I mentioned above.
Old 05-05-2000, 08:43 PM   #6
the spacecowboy
Member#: 765
Post
well it looks like i'll reset it again and do the cycle over again when i come back from playing army for 2 weeks
mabey i'll get lucky and amsoil will have my filter when i come back:-)
thanks a bunch,
space
For those who have had their phase 1 blocks modded for thrust #5... 2slofouru Built Motor Discussion 10 05-27-2010 12:03 AM
For those who have done the Intake Silencer Mod... snvin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 08-19-2004 05:24 PM
Please read for those who have converted intake. AWJunkies Subaru Conversions 3 10-16-2003 07:50 PM
those who have installed an injen intake Die Civic Normally Aspirated Powertrain 3 04-11-2003 08:07 PM
Question to those who have done the hose relocation mod Raslian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-09-2003 09:41 PM
