Welcome to the North American Subaru Impreza Owners Club Saturday September 5, 2015
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 03-31-2000, 05:36 AM   #1
IMPRZIV
Member#: 628
Post K & N Oil Filters
Anyone ever run, or running them now? Anyone know if they have a filter size for the Impreza?? Likes, Dislikes? Thanx...
~Scott
Rally Blue MY99
Owings Mills, Md.
IMPRZIV is offline
Old 03-31-2000, 06:24 AM   #2
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Arrow
I found one to fit my wife's Legacy Outback at the local autozone. The filter casing seemed very strong and it has a nut type fitting on the end. Nice if you have a difficult spot to get to I guess but I find that Subaru's are very easy to change the oil so no real benefit there. In the end I think it's just too costly to justfy since I change the oil every 3K miles anyway. I stick with WIX filters. I can get 2 for the same price as one K&N.
Peaty is offline
Old 03-31-2000, 07:38 AM   #3
kar250c
Member#: 1172
2000 2.5 RS Coupe
Blue Ridge Pearl
Post
Unfortunately WIX filters are worse than FRAM etc. Try Amsoil. You can buy them right off the web. I have been using them for a few months now and they seem to keep the oil looking clean longer.
kar250c is offline
Old 03-31-2000, 07:49 AM   #4
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Thumbs down
I had one on my RS and would not recomend it! The oil takes like 8 seconds after startup to circulate (you could tell this because the oil light kept on after all the others went out, and the sound)
I am back with stock (Purolator) NE1 running the Mobil 1 filters?
Leo
Leonardo is offline
Old 03-31-2000, 11:48 AM   #5
delectron
Member#: 227
Post
I use K&N oil filters. HP-1006 for a MY99 2.5 RS. They have a pressure resistance of 550 psi, and from what I understand subaru's can spike to around 320 psi at startup, possibly popping other filters (like fram).
delectron is offline
Old 03-31-2000, 02:08 PM   #6
BrianR
Member#: 647
Question
Delectron - Do you know if that part number would be the same on a 2000?
BrianR
BrianR is offline
Old 03-31-2000, 03:40 PM   #7
delectron
Member#: 227
Post
BrianR: I don't know, but it's very likely the same.
Old 03-31-2000, 04:12 PM   #8
Gravity
Member#: 137
Post
Not all Fram are junk, I purchased the Fram double filter, which has teflon in it, adn I noticed a slight difference on startup. They are something like $10, but i think they're worth it.
Mike
Gravity is offline
Old 03-31-2000, 05:00 PM   #9
Boom
Member#: 1101
04 STi
like theres a choice BLUE
Post
I love the k&n oil filters, the only thing that I've noticed from the bulletin board is that someone gave you the wrong number to use, its th hp-1004 not the 1006, I got this directly from the parts book. And another person wrote that they used the double guard filter from fram BIG MISTAKE, teflon is one the worst things you can put onto your engine, it burns into a solid black mass over time. I've seen teste that prove it. I would recommend the k&n filter to everyone only because its k&n, they make the best filters in the world. Its the only filter with the 1 inch nut so you can take it off easy and it has an extremely high burst point, another very good feature. Well I hope this helps
Boom is offline
Old 04-01-2000, 12:53 AM   #10
Waltsacura
Member#: 813
07 Outback
Have a Nice Day?
Actually Wix filters are made by the same company that make the OEM Purolator filters for our Subarus, Valvoline, some NAPA filters, and some others that I can't recall now ( I think possibly AC's as well). Fram filters are crap. I have ripped apart most brands of filters to look at the internal design and the filtration system. FRAM and pennsoil filter are identical. I would only run wix or Purolator filter on my Sube. FRAM filters are Wal-Mart junk. The filter paper in FRAM filters are inferior and they don't have the pressure valve that is customary on the WIX and OEM filters...
Waltsacura is offline
Old 04-01-2000, 08:48 PM   #11
DAUTHI
Member#: 840
GC8! '00 2.5RS
Silverthorne and mud
Thumbs down
3M reccomends against using teflon products in an internal combustion engine. FRAM is crap! Ever cut one open? CARDBOARD end caps!!! Paper element that CRUMBLES in your fingers. The only fram filter that is well built it the Tough guard. Uses good metal end caps and a metal and nitrite rubber pressure valve.
my .02
Pete W.
DAUTHI is offline
Old 04-01-2000, 10:06 PM   #12
Tarmac RS
Member#: 1020
Have a Nice Day?
Well, here goes nuttin...
After buying a $10 Mobil1 oil filter and $25 worth of Mobil1, I get home, remove the old filter, drain the oil, and let her drip for about 20 minutes.
Put in the drain plug, reach for my fantastic new Mobil1 FILTER and it wont screw on. !!!
The cross referrence for this filter is wrong and the threads are smaller than required.
So, Im home alone. No oil in the car, no filter for the car. Hmmm, do I put that old filter back on and fill up with my $25 OIL???
Um, lemme think. NO
Caled sis, had her go and pick me up another filter, she calls me back, "they only have FRAM" Im like @#$%, well ok, just get me one.
She gets back, and she told me they only sold the highest of three grades of oil filter for the Subaru. I looked at it, its was a great filter. Used it and am happy with the Quality of FRAM.
Moral of the story, buy a $2.79 FRAM filter, get a piece of shizznitt.
Buy a $9.79 FRAM filter and get quite a respectable unit.
Buy a filter from a company that jsut started making (selling) them? Good luck.
Although the marketing department at Mobil1 did a wonderous job.
Thats my story of a 3hr oil change.
Tarmac RS is offline
Old 04-01-2000, 10:26 PM   #13
XT6Wagon
Member#: 524
04 STi
Post
I would say that the AC delco filters are a heck of alot better than the Fram Filters. A autozone had a bunch cut open to look at, and it was the only $2 filter with metal endcaps. (didn't have a Purolator cut open though). the others with metal endcaps were the $10 Mobil 1 and the $10 K&N. Also from my experiance with my SHO DO NOT GET A FRAM EVER. The test the filter to 2 GPM at some low ass PSI. Hmm the SHO puts out 2GPM at a moderate pressure at 2,000RPM. Turns out a SHO owning Fram engineer did more tests and found out they go into full bypass quickly after the 2GPM. Also I have had problems with the Filter medium colapsing in the Fram filters due to high oil pressure and a slightly dirty filter.
XT6Wagon is offline
Old 04-01-2000, 11:59 PM   #14
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
Go with what you are most comfortable.
And
report back your results for the club database. Currently I believe that there is at least one other person who (dared) to use a FRAM filter on his car which subsequently leaked (burst?). Car lived to tell the tale...
General consensus is that Teflon does not belong in the oil lines of our automobiles.
Champion Labs (makers of Mobil1 filters) claim none of the current filters fit our cars. And will not be held liable for any damage caused by "misapplication" of their product.
Side note: Alex, I-club suggestion, we need to create a product use/don't use database...
Revision is offline
Old 04-02-2000, 11:35 AM   #15
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Arrow
Peaty is offline
Old 04-03-2000, 12:21 AM   #16
jackwei
Member#: 233
Post
hmm, if anyone from Canada remembers me saying that Canadian Tire filters are Purolator, well, they are not anymore, I went and checked yesterday, they aren ot Fram...
uGHHHHHHHHH!
jackwei is offline
Old 10-26-2000, 08:23 AM   #17
GT2RS
Member#: 1077
Post
Can anyone give me the part# for Mobil 1 oil filter?
GT2RS is offline
Old 10-26-2000, 02:23 PM   #18
AndyHidley
Member#: 1031
Post
I see alot of confussion here about the difference between oil filters. check this out for a comparision http://members.xoom.com/_XMCM/minimo...lterstudy.html
AndyHidley is offline
Old 10-27-2000, 07:45 PM   #19
philrb
Member#: 2547
Post
For a conventional pleated paper filter you can't go wrong with AC Delco.
For a synthetic fiber type try a Bosch 3310.
philrb is offline
AMSOIL: The BEST Motor & Gear Oil & Filters WC LATHE WERKS Car Care & Detailing 1 08-19-2009 10:46 AM
02/03 Zerosports Hoodscoop Splitter, GReddy & OEM Oil Filters, Cobb Accessport V1 hoshot Engine/Power/Exhaust 12 05-10-2009 06:03 AM
FS:DE prosports elect boost, oil press, EGT & Oil Filter Adaptor Plate sch3838 Interior/Dressup/Audio & Security 16 06-18-2008 07:13 PM
Buying Oil Filter & Motor Oil Online chaddeus Service & Maintenance 6 04-02-2004 01:41 PM
OEM Oil Filters, OEM Turbo oil filters, fuel filters, spark plugs, air filters LangstonSubaru Vendor 'For Sale' Classifieds 125 03-29-2004 08:25 AM
