Old 04-29-2004, 11:02 AM   #1
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Default Shortblocks
Quick question for all you ej22t guys, if you purchase a new shortblock from the dealership, do the oil pump and water pump come installed on the block already or need to be installed? Just making sure 1000%. Thanks
benjaminetanyahoo is offline   Reply With Quote
Old 04-29-2004, 12:56 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
shortblock=no accessories
u have to supply them
Old 04-29-2004, 07:07 PM   #3
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
does a stock RS oil pump even fit a ej22t shortlbock?
Old 04-29-2004, 07:10 PM   #4
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
from what ive read your supposed to use a wrx or a legacy turbo oil pump because of the oil squirters in the ej22t block. so even if the ej25 pump fits up it might not have the capacity for the block.
Derk1127 is offline   Reply With Quote
Old 04-29-2004, 07:13 PM   #5
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
RS oil pump fits, but use the EJ22T one.
seven881 is offline   Reply With Quote
Old 04-29-2004, 07:24 PM   #6
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
I have been trying to find a picture of the RS pump, do they look the same, with the two nipples on the end when you look from the bottom?
Old 04-29-2004, 07:30 PM   #7
seven881
Member#: 8828
01 BRP 2.2T Hybrid
They look the same, but they're keyed different when you put them on the crank. That was the only noticable difference from the outside.
Old 04-29-2004, 07:32 PM   #8
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
damn it, I might as well change it to be 1000% sure when I do the WRX water pump, damn the man
Old 04-29-2004, 07:36 PM   #9
seven881
Member#: 8828
01 BRP 2.2T Hybrid
You'll be better off trust me. The EJ22T, from what mark has said is the higher pressure oil pump of the WRX, RS and EJ22T. Has something to do with shims or something like that.
Old 04-29-2004, 07:38 PM   #10
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
I just don't feel like doing all that labor, maybe I'll pay somebody to do it and be a lazy ass, yeah if it is a stock RS pump in there now, I am getting away with it because of the low boost I am running but I plan on turning it up in a couple of months with stand alone so I figure do it right. We will see
Old 04-29-2004, 07:44 PM   #11
seven881
Member#: 8828
01 BRP 2.2T Hybrid
If you're doing the water pump already it's like an hour more work since you have the timing belt off already. If you do it make sure to buy a new oil pump seal as well. I didn't and had to have MPJ fix my damn oil leak.
Old 04-29-2004, 07:50 PM   #12
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
how much you think it would run to do that if I get lazy and have somebody do it? couple of hundred huh?
Old 04-29-2004, 07:53 PM   #13
seven881
Member#: 8828
01 BRP 2.2T Hybrid
Yep, somewhere around that. It's a little time cosuming with the timing belt and the sealent has to dry overnight too.
Old 04-29-2004, 07:56 PM   #14
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
maybe I will go that route because then if it leaks I will bring it back and make them fix it again rather me do it all over again. Found a picture of a RS pump looks like the same damn thing, need to do some more investigating, but I know the part numbers are different
Old 04-29-2004, 08:05 PM   #15
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
the WRX water pump has four outlets, I take it the one for the engine oil cooler needs to be clogged unless you have that setup?
Old 04-29-2004, 08:11 PM   #16
seven881
Member#: 8828
01 BRP 2.2T Hybrid
Either run an oil cooler or loop the extra two outlets like me. You could weld them closed too.
Old 04-29-2004, 08:18 PM   #17
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Ya, I wouldnt worry about the water pump unless you were going to run a oil cooler like the wrx has. But the oil pump is a must some RS and the turbo legs had a shim in them that ups the pressure. A must for thoes squirters...
Old 04-29-2004, 10:42 PM   #18
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
good feedback guy, but my thinking is, if I got the timing belt off why not do both for piece of mind?
Old 04-29-2004, 10:42 PM   #19
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
I didn't know the WRXs came with oil coolers?? Not even the STi's.
Wedge is offline   Reply With Quote
Old 04-29-2004, 10:54 PM   #20
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Yeah they do apparently because I got that subscription to Subaru Technical and WRXes have em, actually in all reality WRX Oil Pump and Legacy Oil Pump are the same part number meaning.... same part is what I intepret
Old 04-29-2004, 11:51 PM   #21
totoherbs
Member#: 7321
.... 122 IggPoints
If you search for xephyr like in this thread he talks about how the pumps are different... in one he talks about how you can see them, but I dont remember where.
http://forums.nasioc.com/forums/show...0&pagenumber=2
Old 04-30-2004, 12:45 AM   #22
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
wow great stuff, guess that is settled. totoherbs is like the search wizard and to think I was great at data mining using google. NASIOC search king totoherbs, thanks man
Old 04-30-2004, 01:21 AM   #23
totoherbs
Member#: 7321
.... 122 IggPoints
I pulled that out of my favorites list, while the google ( site:forums.nasioc.com ) search kicks ass. I think its because after being her so long, and spending so much time on nabisco you just know what to look for. And working the sunrise shift opens up a lot of free time.
Old 04-30-2004, 02:21 AM   #24
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
I don't wanna see your favorites list because this isn't the first time you found a link for me, and it probably won't be the last. I hate the search feature on here to be completely honest. I work the sunrise shift as well, but I can only surf nabisco so long
Old 05-03-2004, 02:58 PM   #25
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Difference between the two pumps is the thickness of the rotors. The 'lesser' versions have a thickness of 9mm, the high-flow versions have 10mm rotors, which explains the higher pressure and higher flow.
I have a friend who's running a MY98 EJ25 block / MY91 EJ20G DOHC heads hybrid with standard EJ20 SOHC oil pump. So far, he's done over 15,000 km but the standard internals of the EJ25 open deck engine do not feature the oil jets so it does not have the need for the high flow pump. Mind you, the car is capable of 0-100 km/h times of sub-6s and max out at 260 km/h at 6500 rpm in fifth.
Marnix is offline   Reply With Quote
WTT: JDM v7 EJ207 shortblock for USDM EJ257 shortblock... (Philly / NYC area) TROLL Engine/Power/Exhaust 9 01-14-2007 12:09 AM
v7 sti shortblock v. v8 sti shortblock neep opinions asap. DoctorNick Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 11-22-2005 07:26 PM
What is the difference between a standard STI shortblock and a Crawford S2 shortblock keaniegenie Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 11-16-2005 06:04 PM
USDM 2.5L STi shortblock vs EJ22T Shortblock yellowscooby New England Impreza Club Forum -- NESIC 13 07-25-2005 08:23 AM
WTT JDM v7 shortblock for USDM STi shortblock werkInProgress Private 'Wanted' Classifieds 2 05-23-2005 05:32 PM
