Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-29-2004, 11:12 AM   #1
oceaneer
Member#: 60635
Default To the snuglid guys...
New here, hello all. I am looking into a Turbo, probably going to be a 2005 at this point. Local dealers have told me to expect them in June/July; very hard to find a 2004 here to test drive at the moment - at least without driving an hour or more.
My questions concerns the Snuglid.
1) Can it be secured with the tailgate lowered, or does it just sit there and bouce around?
2) Do you have to use the key to open it? ie If you were in the car with the engine running could your mate open it to chuck a bag in, or do you have to hand over a key? Or put another way, can it be closed but not locked?
Thanks
oceaneer is offline   Reply With Quote
Old 04-29-2004, 01:41 PM   #2
Road Toad
Member#: 49777
04 Turbo Blk/Blk
01 BMW M Coupe Blk/Blk
Default Answers to yer questions
1. The Snuglid locks every time you close it, with latches on each side, so if you close the Snuglid while the tailgate is down, the Snuglid stays latched and locked.
2. Yep, you need to open it every time with a key, unless you pay an extra $150 to get the remote controlled option, then you gotta carry the remote with you.
John
Road Toad is offline   Reply With Quote
Old 04-29-2004, 01:53 PM   #3
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
1) It can be closed with the tailgate down. The Snuglig locks on to rails that are screwed to the existing holes in the BAJA bed. (No drilling needed). There is a latch release so that anyone can open it while the bed is down. This is for safty sake in case someone was locked in there. I think most new cars have this in their trunks. I guess you could cut/ remove the wire if needed. It locks tight so it won't bounce around.
2) The Snuglid comes with a key that is different from the ones that come with the Baja. Kind of like those days when the door key was different from the ignition. I am thinking of taking the truck to a locksmith to see if it can be rekeyed to the same as my Baja key. There is an optional keyless entry system snugtop sells but I don't know if it'll work with this model (the snuglid sl). When you close the lid it locks. You may be able to lower it without it locking but if someone presses down on it all the way, yes it'll lock.
With some skills you may be able to rig a release to the inside of truck from some old car parts I guess. You would probly have to drill a hole or maybe remove some body pannels to pass the cable through.
braveit1 is offline   Reply With Quote
Old 04-29-2004, 02:33 PM   #4
colonelcorn76
Member#: 60723
2004 Baja Turbo
Lightbulb Remote release
There's an idea that would work -- running a cable in a sheath (like a throttle cable or something) and attaching it to the emergency release inside the lid on one end & something inside on the other. I bet there's a hole somewhere in the back panel that would get it through without needing new holes. The throttle cable on my hovercraft is 20 feet long so I know there are cables that are long enough.
On the other hand, rekeying the lock would seem to be a workable scenario too -- even if you have to get a replacement glove box lock from the dealer to get the right lock cylinder & wafers.
On another note, anyone know what the electrical pigtail is that runs out of the insulation layer on the lid is for? I can't see anywhere that there is a light socket in the lid or is it for power for the remote lock?
Jim
colonelcorn76 is offline   Reply With Quote
Old 04-29-2004, 03:02 PM   #5
oceaneer
Member#: 60635
Thank you all. Questions answered. Now I just need the vehicle to try it out on. Stay tuned.
Old 04-30-2004, 03:11 PM   #6
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
I never noticed it. I'll have to check it out after it stops raining tonight.
Old 04-30-2004, 03:52 PM   #7
colonelcorn76
Member#: 60723
2004 Baja Turbo
Question Electrical pigtail
Mine is coming from the front left corner of the lid (when standing behind the car with the lid up). It comes out of the carpet that's used for the undersurface of the lid just behind the left hinge. It has a 16 or 18 ga black & red wire with a plastic connector. There's no mention of it anywhere that I can find.
I'll have to throw a meter on it to see if there's power in it now in case it's to power a light that would attach to it. Otherwise I was thinking it would be used to power the remote lock feature & they just install the wiring in case someone buys the lock afterwards.
Jim
Old 05-02-2004, 10:21 AM   #8
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
Jim
This really has nothing to do with the topic but.... Did you say you had a hovercraft???
I wanna see!
Tkacik is offline   Reply With Quote
Old 05-02-2004, 07:36 PM   #9
colonelcorn76
Member#: 60723
2004 Baja Turbo
Default Hovercraft
I wanna see!
<WAG> Yep. It's a 3 psgr custom model based on the Scat designs. It's got a 65hp Rotax ultralight aircraft engine and a two-bladed wood prop. I've got it on a "fly on fly off" trailer that pivots in the middle. The bed tilts to the rear so I can just fly it up on the trailer and when I want to take it off I just spin it to the right and lower the front of the trailer to the ground to fly it straight off. (Hovercraft usually don't have a reverse.)
Happy birthday to the sexiest guy in the SE!!! HalfBaked South East Region Forum 15 07-26-2003 07:37 PM
Just an FYI to the automatic guys wanting to do a valve body upgrade RiftsWRX Transmission (AT/MT) & Driveline 0 05-12-2003 12:08 PM
To the Michigan Guys going to the SCCA Meet/Autocross sherifx Mid West Subaru Owners Club Forum -- MWSOC 3 04-14-2002 02:38 PM
Props to the great guys at the Queens meet! Sooberman Tri-State Area Forum 4 01-06-2002 06:13 AM
Hi to the new guy with the WR Blue WRX in Lawrenceville Fido Tri-State Area Forum 2 05-15-2001 06:04 PM
