Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-29-2004, 10:59 PM   #1
87rx
Member#: 40423
1998 2.5rs
wrc blue
Default ej25 hesitation
I have a 98 2.5 rs with 60k on it that since february has been hesitating when I am accelerating from a stop.
I only feed it super, and have replaced the plugs, oil/filter,fuel filter,air filter,de wetter treatment,injector cleaner, and switched fuel brands.
does anybody have any insight to this issue?
thanks
87rx is offline   Reply With Quote
Old 04-30-2004, 11:28 AM   #2
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
You might want to look into replacing the ignition wires with a new set of OEMs. Sometimes they tend to start going around 60k so that could be a problem.
Also, you might want to check out the ground mod here. Though it's specifically intented to eliminate mid-range hesitation, I found that it made the whole powerband smoother. Also, try cleaning some of your grounds, as well.
Do you have any mods?
DrBoy01 is offline   Reply With Quote
Old 04-30-2004, 07:41 PM   #3
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
STP Fuel Injector Cleaner, STP Complete Fuel Maintenance and STP Gas Treatment
Honkey3k is offline   Reply With Quote
Old 05-01-2004, 02:22 AM   #4
tre36
Member#: 36707
03 SG5
Have you ever changed your PCV? This is one thing that is often overlooked. Stuck or clogged PCVs causes hesitations and not to say contaminates your engine.
tre36 is offline   Reply With Quote
Old 05-03-2004, 02:10 PM   #5
87rx
Member#: 40423
1998 2.5rs
wrc blue
thanks for the replys, Ill try the grounding fix.
new wires too.
no mods yet, but big plans I also have a 87 rx project that needs work.
thanks for pcv idea.
Old 05-04-2004, 01:03 PM   #6
red22
Member#: 61008
2002 Impreza
black
i have a 02 rs manual that does the same damn thing since a couple of months after i bought it new and no one at the subaru dealership can find anything wrong with it. It has trouble most mornings with first and second gear. can't help you out though
red22 is offline   Reply With Quote
Old 05-05-2004, 12:00 PM   #7
Oquipah
Member#: 9689
1998 Legacy GT
I just had the same thing on my 2.5GT.
Replaced the plugs, wires, fuel filter, air filter and PCV.
Get your system pressure tested...could it be a head gasket issue?
Mine was.
peace,
Oquipah
Oquipah is offline   Reply With Quote
Old 05-05-2004, 09:36 PM   #8
maddbmxjumper
Member#: 43044
01 sedona red ej20
stage 3 vf23 rs
possible rear o2 sensor bad?? i had that prob but with a check engin light
maddbmxjumper is offline   Reply With Quote
Old 05-06-2004, 02:42 AM   #9
joefocker20
Member#: 13745
2015 STI
Ditch your PCV and get a catchcan, get NGK wires and plugs, fuel filter, air filter, and a fresh front 02 Sensor. I'd also replace every single vacuum line. If our fuel pumps have a sock, replace that also.
joefocker20 is offline   Reply With Quote
How long can a properly maintained newer N/A EJ25 last?? tdc17 General Community 14 06-04-2010 12:48 PM
EJ25 build, need help! rcarlson87 Built Motor Discussion 0 06-02-2010 10:36 AM
Hesitate, hesitate, power loss. 25psi Normally Aspirated Powertrain 3 07-19-2003 07:41 AM
98 EJ25 vs all other EJ25s Chapel Normally Aspirated Powertrain 3 04-08-2002 12:11 PM
Ej25 = Ej25? IggDawg Normally Aspirated Powertrain 12 10-21-2001 02:51 AM
