Old 04-30-2004, 12:07 AM   #1
soob102
Member#: 43353
1999 2.5 impreza
Question auto to manual transmittion swap
ok well right now i have a 99' 2.5 impreza AUTO and i love the car i just would like to convert it over to manual and im not sure where to start so if anyone can help me out leave one or u can contact me (aim) soob102 also, if someone has a whole setup please let me know thx.
soob102 is offline   Reply With Quote
Old 04-30-2004, 10:46 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
http://legacycentral.org/library/tra...on/convert.htm
may want to check out the conversion forum as well
Legacy777 is offline   Reply With Quote
Old 05-01-2004, 05:36 AM   #3
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
You will have install pedals. Since this would be using hydralic clutch that will help. Transmission mounts will have to be replaced. And the big kicker which may or may not be a big thing is the crank may not finished to accept the pilot bearing. If not it will have to milled to accept one.
cjfike is offline   Reply With Quote
Old 05-01-2004, 11:10 PM   #4
wawazat
Member#: 13793
2007 specB, 03 Ram
'92 SVX-5 speed
Pilot bearing sits in the flywheel, not the crankshaft. Flywheel bolts to the crankshaft.
I'm converting my SVX to a manual trans.
Todd
wawazat is offline   Reply With Quote
Old 05-04-2004, 12:29 AM   #5
soob102
Member#: 43353
1999 2.5 impreza
Subaru Stars
Thx everyone, all i need to do now is continue working a bunch of hours lol as I choose the setup im going to run.
Old 05-05-2004, 07:41 AM   #6
AdmireWantWillLove
Member#: 24146
2004 GTO
Is it easier to put an auto into a manual than vice versa?
AdmireWantWillLove is offline   Reply With Quote
Old 05-05-2004, 10:19 AM   #7
soob102
Member#: 43353
1999 2.5 impreza
Post 6 speed transmission
since i do not have a STI motor but i have an 2.5 engine could i run a 6speed transmission and would it even be benefical? if so, which transmission would i need to be looking for?
Old 05-05-2004, 11:46 AM   #8
AdmireWantWillLove
Member#: 24146
2004 GTO
Are you turboing the 2.5L or anything?
Or do you plan on getting a WRX or STi motor one day?
Old 05-06-2004, 09:21 PM   #9
soob102
Member#: 43353
1999 2.5 impreza
Default turboing
yes, i do plan on turboing my 2.5L
Old 05-06-2004, 11:59 PM   #10
AdmireWantWillLove
Member#: 24146
2004 GTO
Then yes, I would go for a 6 speed. It would be worth your time you are already putting into the project.
Converting from auto to manual transmission dsc Transmission (AT/MT) & Driveline 3 03-18-2009 12:52 AM
auto to manual transmission swap obsnw Subaru Conversions 10 12-04-2008 03:58 PM
ej22 auto to manual transmission swap wrxracer25 Normally Aspirated Powertrain 5 06-30-2008 05:19 PM
key stuck in ignition after auto to manual wrx swap spiralsmurf Subaru Conversions 7 11-23-2005 04:58 PM
98 Auto to Manual Trans Swap RS25Tuner Subaru Conversions 5 09-23-2004 09:27 PM
