#1 |
Member#: 55007
Vehicle:2000 RSti SilvEaton Resurected and Swapped |
i have a 2000 rs, i plan on swaping in a 91 ej22t short block and keeping my ej25 heads.
1. wht will the compression ratio be? wht will i have to do to get it around 9:1? 2. anyissues using the 25 heads on the 22 block? such as coolant passages or anything like that? or sensor holes that i willl or wont have? 3. is it possible to bore the 22 out to a 25?i want to hone the cylinders anyway and put forged pistons in, but if i can i'd like to bore it out to get more displacement and higher cr with different pistons. any info on this kind of swap will be helpul, thanks - IC
#2 |
Member#: 7321
NESIC
Vehicle:.... 122 IggPoints Work... ahhh... so tired. |
You either didnt search for suck at it.... becasue thats all be answered a number of times before.
Here this thread will answer all your questions.... going to have to do a lot of reading tho. http://forums.nasioc.com/forums/show...highlight=ej22 |
#3 |
Member#: 41300
Vehicle:2000 New York MTA |
see at least the NASIOC search king will at least find it for you, but it has been addressed here and at legacycentral BBS, good luck
#4 |
Member#: 55007
i didnt search at all, i figured someone would just yell at me and post a link out of pitty. thanks alot for the help tho - IC |
| Thread Tools | |
| Display Modes | |
| Questions to those with EJ22T swap. | Eric SS | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 09-21-2011 07:23 PM |
| possible EJ22t swap | huckedup16 | Legacy Forum | 3 | 09-13-2002 03:48 PM |
| EJ22T swap into RS, tranny question? | ImprezedRS | Factory 2.0L Turbo Powertrain | 14 | 06-05-2002 09:16 AM |
| SC EJ22 or EJ22T swap | Witckraft | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 01-02-2002 01:44 PM |
| Finally finished the EJ22T swap. first driving impressions | Eric SS | Normally Aspirated with bolt-on Forced Induction Powertrain | 30 | 11-14-2001 07:41 AM |
