Old 05-03-2004, 09:53 PM   #1
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
Default question to all those w/ heavy spring setups
what are you doing to match the shocks to the springs? if i cant really afford a coilover setup, but i want a car with 500lb springs front/rear, im pretty sure konis won't hold up to the task - what kind of shocks are you using and where can you get springs that'll fit it?
Penguinking is offline   Reply With Quote
Old 05-04-2004, 08:37 AM   #2
sdecker
Member#: 14717
2002 WRX, WR Blue
Complete n00b Racing
Koni will re-valve their struts for a nominal fee. The Koni single adjustable yellow inserts are said to be good for spring rates up to 400 lbs.
One of the national level autox folks (Brian, maybe?) has his re-valved for 400+ lb rates and is very happy with them.
http://forums.nasioc.com/forums/sear...der=descending
There are other threads -- I can't find the one I'm looking for.
Scott
sdecker is offline   Reply With Quote
to all those in the professional workforce, older, and settled, etc... question enozto Off-Topic 31 01-13-2006 02:13 PM
Question to all those with Modded injectors and cold starting? 2002WRXSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 12-23-2004 12:57 AM
yes, another IT question. this goes out to all those who work in a cube. enozto Off-Topic 26 05-27-2004 10:43 AM
To all those with Whiteline springs and stock struts on your WRX JLMarx Brakes, Steering & Suspension 2 05-09-2002 10:34 AM
A ? for all those with H&R/Ver5 setup... Rubasu Brakes, Steering & Suspension 3 06-08-2001 05:21 PM
