Old 04-30-2004, 06:30 AM   #1
opus
Member#: 60812
Default Removing most vacuum lines
I have an '86 GL Wagon. In theory, could you remove all the emmision controls and vacuum lines (except what is needed for cabin controls and vacuum advance)and have the vehicle perform well...or even better?
Basically I am wanting to strip the engine and run it bare....remember engines in the '50s and '60s....on 3 wires and 1 vacuum hose.
opus is offline   Reply With Quote
Old 04-30-2004, 10:33 AM   #2
anders8
Member#: 26658
1 Love Grassroots
NASA Rally Sport FTW!
You need to go through each system, decide what it does, and see if that will give you a performance advantage. Most won't.
Even better? I would doubt that you would feel anything in your butt-dyno from an "optimized" vacuum arrangment.
anders8 is offline   Reply With Quote
Old 04-30-2004, 06:09 PM   #3
opus
Member#: 60812
I guess it amazes me that I can find no one that has ever removed all the vacuum hoses and ran the engine. I might just do it so someone in the world would have accomplished it.
One of the main reasons of wanting to do this is so I an adjust the carb. As it sits now, I cant even see the carb.
Old 04-30-2004, 07:34 PM   #4
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
try posting your question in the 'old generation' forum at www.usmb.net those guys have some really old soobs running GOOD!
1 Lucky Texan is offline   Reply With Quote
Old 04-30-2004, 07:39 PM   #5
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
hell yea, i will vouch for that. I saw a pic of an oldschool GL doing a 12sec qt mile, damn
Honkey3k is offline   Reply With Quote
WTB: Restrictor pill for factory turbo vacuum lines & factory turbo vacuum lines roninsoldier83 Private 'Wanted' Classifieds 4 10-01-2007 09:14 PM
all vacuum lines from one point very bad?? jdchmiel Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-05-2001 08:31 PM
Pics of AVC-r Vacuum lines. Keith Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-18-2001 09:03 PM
What vacuum line filter is this? OBSS Normally Aspirated Powertrain 0 04-18-2001 03:01 PM
Where can I find a small in-line air filter for vacuum line. Tim Prudence Normally Aspirated Powertrain 3 12-04-2000 03:38 PM
